C/C++ Delete File Contents by Roll Number | C++ Code for Deletion
  • Thread starter Thread starter Suyash Singh
    c++ delete file
The forum discussion centers on a C++ program designed to delete student records from a binary file based on a roll number. The code uses fstream for file operations and encounters issues where the entire file is deleted instead of just the specified record. Key suggestions include implementing error checking for file operations, using a debugger to step through the code, and understanding the behavior of the remove() and rename() functions. Additionally, participants emphasize the importance of incremental development and testing to identify and resolve issues effectively.
  • Understanding of C++ file handling using fstream
  • Familiarity with binary file operations in C++
  • Knowledge of error handling in C++ standard library functions
  • Experience with debugging tools like GDB
  • Research C++ fstream error handling techniques
  • Learn about the behavior of remove() and rename() functions in C++
  • Explore incremental development practices in software engineering
  • Study how to use GDB for debugging C++ applications
C++ developers, software engineers, and students learning file handling and debugging techniques in C++. This discussion is particularly beneficial for those working with binary files and seeking to improve their coding practices.
Suyash Singh
ok i wrote my code but the whole file gets deleted instead of the required values.
Code:
    else if(option==5)
              int rno;
              fstream w1;fstream e1;
              e1.open("temp.dat",ios::in|ios::out|ios::binary);
              w1.open("file.dat",ios::in|ios::out|ios::binary);
              cout<<"\nEnter roll number to delete";cin>>rno;
              bool value=false;
              while(w1.read((char*)&s1,sizeof(student)))
                  if(s1.rno==rno)
                      value=true;
                  else
                       e1.write((char*)&s1,sizeof(student));
              e1.close();
              w1.close();
              if ( value == false ) {
                  cout<<"\nNot found"<<endl;
              } else {
                   remove("file.dat");
                   rename("temp.dat","file.dat");
Technology news on Phys.org
Have you tried running portions of your program?
- test the portion upto and including the two file closes, print value what happens?
- add prints to your while loop so you see how each line is handled
- test renaming file.dat instead of removing it to see if the rename works as expected
research the apis for remove and rename to see what they do and what problems they may have
You haven't provided enough detail about s1 and about student, using the sizeof function could mean you writing out nulls whereas it looks like s1 is a char array?
Do you have a debugger that you can run your program step by step?
Likes Mark44
student is structure while s1 is the object of student
here is my complete code.
Code:
#include<iostream>
#include<fstream>
using namespace std;
struct student
    char name[80];
    int rno;
int main()
        student s1;
    int option,n;
    char ch;
    do
    cout<<"Enter 1 to write file\nEnter 2 to read file\n3 to search file\n4 to modify file\n5 to delete";cin>>option;
    if(option==1)
    ofstream f1;
    f1.open("file.dat",ios::binary);
    cout<<"Enter number of customers";cin>>n;
    for(int i=0;i<n;i++)
    cout<<"\nEnter name(dot to terminate)";cin.getline(s1.name,80,'.');
    cout<<"\nEnter roll number";cin>>s1.rno;
        f1.write((char*)&s1,sizeof(student));
      f1.close();
    else if(option==2)
           ifstream r1;
           r1.open("file.dat",ios::binary) ;
                while(   r1.read((char*)&s1,sizeof(student)))
           cout<<"Name"<<s1.name<<endl;
           cout<<"Roll number"<<s1.rno<<endl;
           r1.close();
    else if(option==3)
        int rno;
        cout<<"Enter roll number to search for";cin>>rno;
       bool condition=false;
        ifstream a1;
        a1.open("file.dat",ios::binary);
        while( a1.read((char*)&s1,sizeof(student)))
        if (rno==s1.rno)
                    condition=true;
                    cout<<"Name:"<<s1.name<<endl;
    if(condition==false)
    cout<<"Not found"<<endl;
    a1.close();
    else if(option==4)
        int r;
        fstream q1;
        q1.open("file.dat",ios::in|ios::out|ios::binary);
        cout<<"Enter roll number to modify";cin>>r;
        bool flag=false;
        while(q1.read((char* )&s1,sizeof(student)))
            if(s1.rno==r)
                flag=true;
                cout<<"\nEnter new name(dot to end input)";cin.getline(s1.name,80,'.');
q1.write((char*)&s1,sizeof(student));
        if(!flag)
        q1.close();
    else if(option==5)
        int rno;
              bool value=false;
                  if(s1.rno==rno)
                      value=true;
                  else
                                      e1.close();
              w1.close();
                             if(value==false)
                else
                     remove("file.dat");
    cout<<"Do you want to continue?(y/n)";cin>>ch;
    }while((ch=='y')||(ch=='Y'));
               return 0;
To add to what @jedishrfu said, the remove() standard library function returns a value, which you are discarding. The return value is zero if this function succeeded in removing the file. If it failed, the function returns some nonzero value. The rename() standard library function works the same way, returning zero if it is successful and a nonzero value if it isn't.
Another problem that people run into when they're working with files is that if you don't provide the full path to the file, it needs to be in a directory that the program can find. For example, with Visual Studio, if you run your code in the debugger, the file has to be in the same directory as the source code. If you run your program from the command line, the file needs to be in the same directory as the executable. If you provide the full path to the file (which you aren't doing), it doesn't matter where the file is. Things are probably similar with other compilers.
Likes jedishrfu
@Suyash Singh, the advice from jedishrfu about using a debugger is something you should think hard about doing. Using a debugger can answer a lot of questions.
Another problem that can come up is when your program inputs a mix of numbers and characters. Input from the keyboard is buffered, so when you press the 1 key, you're really pressing two keys -- the 1 key and the Enter key. If you program later is expecting a character (like y or n), the character that gets stored is actually the newline character ('\n') left over from when you entered a number. Using a debugger is very helpful in showing this.
Few points:
1) Error checking. You are not handling a single error in your entire program. f1.open can fail, as can rename, and remove.
2) Correct IO. You open both files with the flags ios::in|ios::out|ios::binary. For the output file ,you don't need ios::in and for the input file, you don't need ios::out.
3) Timing. remove() may return before the operating system cleans up the file. Give the OS a moment to clean up its buffers before trying to immediately to a rename.
Learn how to step through with GDB.
Likes jedishrfu
Thank you, it’s always good to have problems like these and to thank everyone involved because each post builds up to the eventual solution and some of our advice may help you in the future even though you’ve yet to realize it.
Also really spend some time learning the language debugger tool. It will really save you in the future in ways too numerous to explain.
Likes Suyash Singh
Unless I'm very sure about what I'm doing (i.e. I've done it a number of times before), I develop and test my code incrementally, with successive versions that do more things. I don't write the whole program in one shot and then start debugging it. In this case it would go something like this:
Version 1: Open the input file, read the data and simply display it.
Version 2: In addition, open the output file and write the data to it without modification or selection. That is, in effect, simply copy the file. Assuming the output file is supposed to be in the same format as the input file, I would test it by running the program again, using the output from the first run as input.
Version 3: Finally, add the selection logic for the records that you actually want to write.
At some point I would remove the data-display statements which are presumably not needed in the final product.
Likes DrGreg and Suyash Singh
I will learn debugger as soon as possible.
Also is it possible to add contents between already present data in a file.Like using 'ate' or 'app'.I mean is it possible?
Could anyone give me some sort of hint on how to begin?
i also prefer writing my code that way
As far as I can tell, at least with standard C++ file streams, you cannot insert new data directly into the middle of a file unless it actually replaces (overwrites) the same amount of existing data. To do a pure insert, keeping all the existing data intact, I think you have two choices:
Method 1:
  • Read the entire file into the program, using some kind of data structure (array, vector, list, etc.).
  • Insert the new data into the data structure.
  • Write the updated data structure into a new file.
  • Delete the old file (or rename it as a backup file) and rename the new one.
Method 2:
  • Read data from the old file and write it to a new file, up to the point where you want to insert the new data.
  • Write the new data to the new file.
  • Read the remaining data from the old file and write it to the new file.
Likes Suyash Singh
you could use random file i/o but for the insert you'd need to read and write the data block following the insertion point much as you would if you were inserting into an array.
Another approach is to use some sorting of indexing scheme that is store your data as a linked list so that you can write the inserted data at the end of the file and adjust link nodes to find it. But this is a lot like reading from the old file, inserting the new data and then reading the remainder writing everythin to a new file. Also its marginally easier if your data blocks are of fixed size.
https://en.wikipedia.org/wiki/ISAM
Likes Suyash Singh
  • · Replies 33 ·
  • · Replies 75 ·
  • · Replies 30 ·
12K
  • · Replies 17 ·
  • · Replies 17 ·
