Bandwidth Filtering: Get Help Solving Last Problem
  • Context: Engineering
  • Thread starter Thread starter snatchingthepi
    Bandwidth Filter
The discussion focuses on solving a Digital Signal Processing (DSP) problem related to determining the 3dB bandwidth of two filters, specifically the transfer functions H1(z) and H2(z). Participants suggest plotting the magnitude of each filter and identifying the upper and lower -3dB frequencies to find the bandwidth. The filters are defined as H1(z) = (1-a)/(1-az-1) and H2(z) = (1-a)/2 * (1+z-1)/(1-az-1), with the condition 0 PREREQUISITES
  • Understanding of Digital Signal Processing (DSP) concepts
  • Familiarity with transfer functions and their representations
  • Knowledge of plotting functions in a mathematical context
  • Basic grasp of -3dB bandwidth calculations
  • Learn how to compute the magnitude response of digital filters
  • Study the concept of -3dB bandwidth in signal processing
  • Explore the use of MATLAB or Python for plotting filter responses
  • Investigate the implications of filter coefficients on bandwidth
This discussion is beneficial for students and professionals in Digital Signal Processing, particularly those working on filter design and analysis, as well as anyone seeking to enhance their understanding of bandwidth calculations in DSP applications.
snatchingthepi
Determine the 3dB bandwidth of the filters
$$ H_1(z) = \frac{1-a}{1-az^{-1}} $$
$$ H_2(z) = \frac{1-a}{2} \frac{1+z^{-1}}{1-az^{-1}} $$
if 0<a<1
Not sure.
Hi everyone
I am finishing the last problem for a DSP problem set and just frankly have no idea where to start this one. I'm thinking I could compute the magnitude of each filter and then compare, but again am not sure. Can anyone point me in the right direction?
Thanks
Try that first. Plot the magnitude like you were saying. You have to show some work or attempt before people can help you here.
edit:
When you plot it: Are you going to plot as a function of ##z## or as something else? Did the professor use anything else or give you an equation where ##z## was some function of something else that had ##\Omega## in it?
snatchingthepi said:
Homework Statement:: Determine the 3dB bandwidth of the filters
if 0<a<1
Relevant Equations:: Not sure.
You can just figure out where the upper and lower -3dB frequencies are from each transfer function...
These posts were enough to encourage me to find a good answer. Thank you both.
  • · Replies 49 ·
