Final temperature of ice mixed with water
The final temperature of a mixture of 3.00 kg of crushed ice at -3.0°C and 4 liters of water at 10.0°C is 0°C. The calculations involve determining the energy required to raise the ice to 0°C, which is 19800 J, and the energy available from the water, which is 168000 J. The melting energy of the ice is 999000 J, indicating that not all ice will melt. The conclusion is that the water cools to 0°C before all the ice melts, establishing the final temperature at 0°C.
  • Understanding of specific heat capacity (water: 4.2 J/kg·K, ice: 2200 J/kg·K)
  • Knowledge of phase change energy calculations (melting energy: 333,000 J/kg)
  • Basic principles of calorimetry and energy conservation
  • Ability to perform calculations involving mass, temperature change, and energy transfer
  • Study the concept of calorimetry in detail, focusing on energy transfer during phase changes.
  • Learn about specific heat capacity and its applications in thermal energy calculations.
  • Explore advanced topics in thermodynamics, including enthalpy and energy conservation laws.
  • Practice problems involving mixed systems of solids and liquids to solidify understanding of heat exchange.
Students in physics or chemistry, educators teaching thermodynamics, and anyone interested in understanding heat transfer and phase changes in mixtures.
Pouyan
What will be the final temperature of 3.00 kg of crushed ice with temperature -3.0 C mixed with 4 liters of water with temperature 10.0 C? We can ignore all the energy exchange with the environment
What I do know and I do:
the weight of the ice = 3 kg
Ice temprature = -3 C
melting energy = 3 kg * 333 000 J / kg = 999000 J
weight of water = 4 kg
specific heat capacity of water = 4.2 Jk / kg K
specific heat capacity of ice = 2200 Jk / kg K
I understand just melting energy, but I do not know how will I find out the final temperature. A solution that I have but do not understand why :
dQ ice = 3 * 2200 * (0 + 3) = 19800 J
dQ water = 4 * 4200 * 10 = 168000 J
Melting energy = 999000 JEnd temperature becomes equal to 0. but how can I find it?!
Break the problem into steps. First heat the ice to 0oC and cool the water to 0oC (as you already have) and then consider the available melting energy. Can you use all of it?
Likes Pouyan
dQ s = 3 * 2200 * (0 + 3) = 19800 J
Well, you must do some visualization of what is happening to the ice when it is mixed with water.
1. The ice cannot melt until its temperature reaches the melting point of ice. Since the ice temperature is initially -3° C, it takes a certain amount of heat to raise its temperature to 0°C. Where does this heat come from?
2. Once the ice is at 0°C, then it can begin to melt, but it needs even more heat to do this. Where does this heat come from? What happens if there is not sufficient heat to melt all the ice?
Likes Pouyan
Think in terms of steps (You've already done the calculations):
How much energy is available if the water went to 0 degrees?
How much energy is required to raise the temp of the ice to 0 degrees?
How much energy is required to melt all the ice? Is there enough energy?
Likes Pouyan
Ok and thank you guys. I think I understand that Ice will reach 0 from -3 and water will do that too from 10 to 0. For Ice we have a melting energy and (Q ice). For water (Q water) but if this is so why should we calculate energies?!
1- We need a melting energy which is 999000 J. I think the ice raises 0 with 999000 J and becomes liquid with dQ ice = 19800 J
2- In this part the ice is mixed with water which is 10 C. I think dQ water = 168000 J helps the water and ice to reach 0.
But I am on the right path?
You need the energy contained in the water to see if it is enough to (1) raise the temp of the ice to the melting point, and (2) melt all the ice. If there's energy left over, that means the newly formed water will end up with a final temp above zero.
Likes Pouyan
OK I see that dQ water = 168000 J, dQ ice=19800 J and melting energy of ice = 998000
dQ ice + melting energy of ice > dQ water
or dQ water / (dQ ice + melting energy) is less than 1.And because of this we can say the final temperature is 0 ?!
Sure.
Think in steps:
Can you raise the temp of the ice to freezing? Yes! How much of the water's energy is left?
Is there enough to melt all the ice? No! So at some point, the water will get to 0 degrees before all the ice is melted. Final temp must be zero.
Likes Pouyan
Doc Al said:
Sure.
Think in steps:
Thank you so much for help.
At first time, I was just thinking like this
dQ loss = dQ gain
or
dQ ice = dQ water
But sometimes I confuse these types of issues with other calorimetry calculation
  • · Replies 17 ·
