Final Temp of Water & Zinc: Find the Answer
The final temperature of a system consisting of a 10 kg piece of zinc at 68°C and 32 kg of water at 14°C can be calculated using the principle of conservation of energy. The specific heats of zinc and water are 388 J/kg·°C and 4180 J/kg·°C, respectively. By setting the energy gained by water equal to the energy lost by zinc, the equation (10 kg)(388 J/kg·°C)(Tf - 68°C) + (32 kg)(4180 J/kg·°C)(Tf - 14°C) = 0 can be solved for the final temperature Tf. The calculations lead to a final temperature of approximately 41°C.
  • Understanding of thermal equilibrium and heat transfer principles
  • Knowledge of specific heat capacity and its application in thermal calculations
  • Ability to manipulate algebraic equations to solve for unknowns
  • Familiarity with units of measurement in physics (e.g., kg, °C, J)
  • Study the laws of thermodynamics, particularly the first law regarding energy conservation
  • Learn about specific heat capacity and its role in different materials
  • Explore more complex heat transfer problems involving phase changes
  • Practice solving thermal equilibrium problems with varying masses and temperatures
Students studying physics, particularly those focusing on thermodynamics, as well as educators looking for practical examples of heat transfer and energy conservation in real-world scenarios.
DrMcDreamy
A 10 kg piece of zinc at 68◦C is placed in a container of water. The water had a mass of 32 kg and a temperature of 14◦C before the zinc was added. The specific heat of zinc and water are 388 J/kg ·◦C and 4180 J/kg ·◦C. What is the final temperature of water and zinc? Answer in units of ◦ C.
How do you do this? What formula do I use? TIA
Think about the law of energy conservation. If you assume that the system is insulated from the surroundings, then any heat transferred from the water will be absorbed by the zinc. i.e.:
Energy gained by water = energy lost by zinc
You also know that two objects in contact will eventually reach thermal equilibrium, so that their final temperatures are the same. What final temperature, T, will make the energy transferred by the water and zinc equal?
So is it 41 C?
mZnCZn(Tf-TZn i) + mH2OCH2O(Tf-TH2O i)=0
When I plug in my numbers:
(10 kg)(388 J/kg C)(Tf-68 C) + (32 kg)(4180 J/kg C)(Tf- 14 C) = 0
3880 J/C (Tf-68 C) + 133760 J/C (Tf- 14 C) = 0
Than?!
  • · Replies 17 ·
  • · Replies 16 ·
