Final velocity given acceleration and initial velocity
The problem involves a rock launched straight upward by a dynamite blast, with a focus on determining its initial velocity and speed after a specified time, given the effects of gravity and assuming no air resistance.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to use the kinematic equation to find the initial velocity and later the speed after a certain time. Some participants question the distinction between speed and velocity, noting that the problem specifically asks for speed.
Participants have provided guidance on the difference between speed and velocity, and some have confirmed the calculations for the initial velocity. There is ongoing discussion about the correctness of the final speed calculation, with multiple interpretations being explored regarding significant figures and rounding.
There is mention of significant figures based on the initial conditions provided in the problem, which may affect the final answer's presentation. The original poster expresses uncertainty about the feedback received from the homework submission.
Ohoneo
A dynamite blast at a quarry launches a chunk of rock straight upward, and 2.1 s later it is rising at a speed of 19 m/s. Assuming air resistance has no effect on the rock, calculate its speed at (a) at launch and (b) 5.2 s after the launch.
v = v0 + at (I'm assuming is the only relevant one, although I'll post two others in case they are needed)
x = x0 + v0t + a/2 t^2
v^2 = v0*2 + 2a(x-x0)
I solved part A by plugging into the equation v = v0 + at
19 m/s = v0 + (-9.8 m/s^2)(2.1 s)
And I found that the initial velocity equals 40 m/s.
So, to solve part b, I should just have to plug the initial in and find the final. I tried that:
v = 40 m/s + (-9.8 m/s^2)(5.2 s)
v = -11 m/s
However, when I entered that solution in for the homework, I was told it was wrong. I'm not really sure how to go about doing the problem if that's incorrect. I thought maybe I could have an error in rounding with significant figures.
Thanks for the help!
It could be that since part b asked for the speed, not the velocity, that the sign of the number reported should have been positive.
The problem asked for the speed of the rock - you gave its velocity. Remember - speed is a scalar (independent of direction), and velocity is a vector (depends upon direction).edit: gneill and I were posting at the same time, apparently.
I tried that as the answer (11 m/s instead of -11 m/s) and it was still incorrect.
No, that is the correct answer. 11.38 m/s to be "precise," but you're only given two significant figures in your initial conditions. I've done it three ways, and it comes to 11.38 m/s each time. And 40 m/s is correct for a. Just now, I did it a 4th way, and I got 10.96 m/s - which still rounds to 11 m/s.
Okay, so I did do the math correctly. Thanks for your help :) I'm going to email my professor and see what the issue is with that problem.
  • · Replies 17 ·
