Find a function that satisfies the following Differential Eq
6 replies · 2K views
SqueeSpleen
I'm helping some guys with Calculus I class and found this exercise in the practice about integrals.
I think it's overkill but it may have some easy way to solve it.
I'm very rusty solving differential equations.
1. Homework Statement
Find f differentiable such that
(3+f'(x))e^{2-x} = (x-6) (3x+f(x))^{2}
with f(2)=0.
I have solved similar exercises searching a function g(x) such that g(f(x))'=g'(f(x)).f'(x) and and putting the equation in a way that you have g'(f(x))=h(x). So you can integrate and solve it. The most classic example is (ln(f(x))'=f'(x)/f(x), but I have done with more complicated functions. In this case I had to go to wolframalpha because I couldn't figure out the solution, and even seeing the solution I'm not having an easy time finding it, I only was able to verify that's a solution. If it were a linear differential equation it would be easier, but the square spoils everything.
I also thought about integrating by parts the left part of the equality, but I'm not sure if it will help to arrive an easier equation as I don't know what to do with the expressión on the right.
Any suggestions? I'm very rusty with differential equations but as this exercise was in a calculus 1 class I think it should be easier to solve.
Thank you for your help!
with f(2)=0.
Try to solve it for the function g(x) = 3x+f(x)
Let's see if I got it.
Let g(x)=f(x)+3x. Then g'(x)=f'(x)+3.
So the equation becomes
g'(x).e^{2-x} = (x-6) g(x)^{2}
We work the expression
\dfrac{g'(x)}{ g(x)^{2} } = (x-6) e^{x-2}
We re-write the expression on the left
-( \dfrac{1}{g(x)} )' = \dfrac{g'(x)}{ g(x)^{2} } = (x-6) e^{x-2}
So
( \dfrac{1}{g(x)} )' = (6-x) e^{x-2}
Now all we have to do is to integrate and find the g(x) (and so f(x))
So
It will be all right.
Thank you for your help. Also, your signature is great, having at hand those symbols is very convenient.
All ready answered while I was typing.
You find those symbols and a couple of more by hitting the ∑ button above if you write a post. .
