Find all points of intersection
6 replies · 2K views · last reply
Addez123
Find all points where the level surface
$$4x^2+y^2+z^2 = 8$$
and
$$x^2+9y^2=z^2$$
intersects eachother at a 90 degree angle.
Surface 1: $$4x^2+y^2+z^2 = 8$$
Surface 2: $$x^2+9y^2 - z^2 = 0$$
First I try to visualize it:
w = Surface 1, is a spheroid
w_2 = Surface 2 is a cone stretching up the z axisThen I calculate their gradients:
$$∇w = (8x, 2y, 2z)$$
$$∇w_2 = (2x, 18y, 2z)$$
The points where they intersect at 90 degrees is when dot product is zero.
$$∇w \cdot ∇w_2 = 0$$
$$16x^2 + 36y^2 - 4z^2 = 0$$
$$z^2 =4x^2 + 8y^2$$
This is a cone stretched differently in x and y axis, but a cone none the less.
Now I need to find where this cone intersects with EITHER the sphere (Surface 1) or the inital cone (Surface 2). Where these intersects, curve 1 and 2 intersect under 90 degree angle. This happens when I set $$z^2 = z_2^2$$.
I use the cone, Surface 2, equation:
$$x^2 + 9y^2 = 4x^2 + 8y^2$$
$$3x^2 - y^2 = 0$$
This is where I get confused. There's no z coordinates so if this was a circle I'd assume it was a cylinder stretching up the whole z-axis.
But the answer is suppose to be either just points, or a curve. It makes no sense that the intersection would create another surface.
What am I doing wrong?
Addez123 said:
Homework Statement:: Find all points where the level curves
My guess is you never make use of this 'level curves' in the problem statement
By the way
Addez123 said:
is a sphere
No. It is a spheroid.
By the way
I do use the level surfaces, especially when I combine surface 2 with the surface representing all points at which the two functions form 90 degree angles:
Mark44 said:
From post 1:
You have a sign error in this equation.
Thanks! I saw that before tho and changed everywhere but apparently forgot to change that line. Eitherway you can see the dot product is still correct.
Can someone move this to the calculus sub-forum? This isn't homework.
