How to Find the Angle Between Two Vectors?
  • Thread starter Thread starter Michaelh926
    Angle Vectors
To find the angle between two vectors given their dot product and cross product, the magnitude of the cross product |u x v| is calculated as |u x v| = √(2^2 + 3^2 + 1^2) = √14. Using the relationship |u x v| = |u||v|sinθ and the dot product u·v = |u||v|cosθ, the equations can be combined to derive tanθ = √14/5. Solving for θ using arctan(√14/5) provides the angle in degrees. This method allows for determining the angle without needing the individual vectors u and v.
Michaelh926
Question:
Let u·v = 5 and u×v = 2i+3j+k. Determine the angle (in degrees to one
decimal place) between the two vectors.
Im not sure on what to do with the equation given since other examples that were done i was given separate equations for u and v
We were told this formula will be used but not sure how to get u and v.
|u x v|=|u||v|sinθ
Thanks in advance to anyone that helps
Michaelh926 said:
Question:
|u x v|=|u||v|sinθ
What is the value of |u x v|? From that you should be able to work out the value of tanθ and then θ without needing to find u or v.
AM
so, the value of |u x v|=sqrt(2^+3^+1^)?
then substitute it so it will be |sqrt(2^+3^+1^)|=|u||v|sinθ?
AM
You're missing the exponents of 2 (squares), but yes.
Now find a similar expression for the dot product, divide and form a simple trig equation.
Sorry, forgot to put the exponents in.
So will this be what it comes to...
sinθ=sqrt(14)/5 then solve for theta?
Not quite. You said:
(1) uvsinθ = √14
(2) uvcosθ = 5
Solve for θ.
AM
No. Isn't there a cos θ in the definition of the dot product?
Andrew Mason's post gives you the equations you should divide.
so is it
√14/sinθ=5/cosθ
tanθ=√14/5
θ=arctan(√14/5)?
Michaelh926 said:
so is it
√14/sinθ=5/cosθ
tanθ=√14/5
θ=arctan(√14/5)?
Yes.
Curious3141 said:
Yes.
:) now i understand it.
thank you to everyone that helped
  • · Replies 21 ·
  • · Replies 30 ·
