MHB How do I find the angles in a triangle?
  • Thread starter Thread starter gazparkin
    Angles Triangle
To find the angles in a triangle, it's essential to know that the sum of all angles equals 180 degrees. For a triangle with two angles of 122 degrees, the third angle can be calculated as 64 degrees. In another triangle with a right angle and a 37-degree angle, the third angle is found to be 53 degrees. For an isosceles triangle with base angles of 63 degrees, the third angle is calculated as 54 degrees. Finally, using these angles, the value of x in a straight line equation can be determined as 73 degrees.
gazparkin
Hi,
I'm trying to work out how I'd calculate the values in the below. Rather than just have the answer, I'd really like to understand how I'd calculate this. Thank you in advance!
Mathematics news on Phys.org
For the first question, you need to know two things.
1. A straight lines forms an angle of 180 degrees
2. All angles in a triangle must add up to 180 degrees.
Use the first principle to solve for the two interior angles of the triangle other than x. It would look like this:
180 degrees = 122 degrees + interior angle
interior angle = 180 degrees - 122 degrees = 58 degrees.
The calculation is the same for both angles, since they are both 122 degrees.
Now you have a triangle with interior angles 58 degrees, 58 degrees, and x.
Use the second principle (all angles in a triangle add up to 180) to solve for x.
x + 58 degrees + 58 degrees = 180 degrees
x = 180 - 58 degrees - 58 degrees
x= 64 degrees.
For the second question, you need to know the two things above, plus the fact that
3. Isosceles triangles have two sides that are the same length, and therefore two angles that are the same measure. Those angles are the base angles.
Start by looking at the triangle furthest to the right. You are given that the triangle has one right angle, and one angle that is 37 degrees. Using the fact that all angles add up to 180 degrees, solve for the third angle.
Third angle + 37 degrees + 90 degrees = 180 degrees
Third angle = 180 degrees - 37 degrees - 90 degrees.
Third angle = 53 degrees.
Now, move on to the second triangle. Use the fact that this triangle is isosceles, and therefor its base angles are the same. This means that the other base angle also has a measure of 63 degrees.
Now, we know two angles of the second triangle, and can solve for the third using the same method as above.
Third angle + 63 degrees + 63 degrees = 180 degrees.
Third angle = 180 degrees - 63 degrees - 63 degrees
Third angle = 54 degrees
Now you can use the fact that a straight line forms an angle of 180 degrees to solve for x.
x + 54 degrees + 53 degrees = 180 degrees
x = 180 degrees - 54 degrees - 53 degrees
x = 73 degrees
Thank you so much Catmitt98 for the detailed response. This makes complete sense. :):):)
Thanks again!
Good morning I have been refreshing my memory about Leibniz differentiation of integrals and found some useful videos from digital-university.org on YouTube. Although the audio quality is poor and the speaker proceeds a bit slowly, the explanations and processes are clear. However, it seems that one video in the Leibniz rule series is missing. While the videos are still present on YouTube, the referring website no longer exists but is preserved on the internet archive...
  • · Replies 19 ·
