Solve Antiderivative of xe^x | Step-by-Step Guide
The discussion focuses on finding the antiderivative of the function \( xe^{x} \). Participants clarify that the initial attempts at solving the problem, such as proposing \( x^{e^x + 1} \) as the antiderivative, are incorrect. The correct approach involves recognizing that the exponent \( e^x + 1 \) is not a constant and applying the chain rule for differentiation. The conversation emphasizes the importance of verifying proposed solutions through differentiation.
  • Understanding of basic calculus concepts, including derivatives and antiderivatives.
  • Familiarity with the chain rule in differentiation.
  • Knowledge of exponential functions and their properties.
  • Ability to manipulate and differentiate power functions.
  • Study the application of the chain rule in differentiation.
  • Learn about the properties of exponential functions, particularly \( e^x \).
  • Explore techniques for finding antiderivatives of complex functions.
  • Practice differentiating functions with variable exponents, such as \( x^{e^x} \).
Students studying calculus, particularly those seeking to understand antiderivatives and differentiation techniques, as well as educators looking for examples of common misconceptions in calculus.
dfklajsdfald
Member warned that an effort must be shown
find the anti-derivative of xe ^x so its x to the power of e to the power of x
i have 0 idea where to even start. this was a question on my quiz today
Hi dfk,
No homework. Still an attempt on your part required :biggrin: $$ F'(x) = x^{e^x} \ \Rightarrow \ F(x) = ??$$
well i know that the derivative of ex is ex so the anti derivative of ex is ex and then my attempt would be exx but i don't know if that's right or even a good start
BvU said:
Hi dfk,
actually scratch the last part. my attempt would be xe^x +1 becacuse normally for any function x u go x and add one to the power and divide by it
So is ##\frac d{dx}(x^{e^x + 1}) = x^{e^x}##?
For a power function, such as ##x^n##, the derivative is ##nx^{n - 1}##, but is that what you have here?
Do you confirm that the formula in #2 is the one you meant?
Then you don't need to ask us whether a proposed solution is correct, surely you can differentiate?
If then you find it wrong, It may at least suggest something else to try. Or maybe some other direction to look.
i don't know what ur asking, the question is find the antiderivative of the function x to the power of e to the power of x as stated at the start. I am not asking whether or not a solution is correct I am asking how abouts would i go to try and get the antiderivative because I've tried multiple ways (one which i have stated in a different reply) and can't seem to get there. I am only asking for guidance not for an answer of whether or not my solution is correct.
what i meant was that it was my attempt at finding the antiderivative of xex. i know that the derivative of ex is ex therefor the anti derivative would be the same. so then for derivatives with base x you go xn-1 times the derivative of the power but since i need the anti derivative wouldn't i do xn+1 divided by the power instead? so wouldn't it be xe^x +1 all divided by ex(the plus one is added to ex not to the entire function I am just having trouble showing it up on here properly)
That's not how it works -- you are applying the power rule for a function for which it doesn't apply.
Power rule: ##\frac d{dx} x^n = nx^{n - 1}##
Here the exponent, n, is a constant. For your function the exponent, ##e^x + 1## is not a constant.
By your reasoning, ##\frac d{dx} x^x =xx^{x - 1} = x^x##, which isn't true. The derivative of ##x^x## is actually ##x^x(\ln x + 1)##.
To get the derivative, write ##x^{e^x}= e^{f(x)}##, where ##f(x) = \ln(x) e^x##, and use the chain rule.
I thought and rereading #3 it still looks to me you were asking whether an answer was correct. We do often get to ask that question for integrals and have to point out that checking is the easy part - and also necessary. It seems to me you have now got some guidance to work on.
ya but the question is asking for antiderivative
You claimed earlier that the antiderivative was ##x^{e^x + 1}##. If this is correct, you should be able to differentiate this function to get your original integrand. That's what we're helping you with.
On the other hand, if you differentiate ##x^{e^x + 1}##, and DON'T get ##x^{e^x}##, then that tells you that your purported antiderivative is incorrect.
ohh okay that makes more sense. and i wasnt claiming that that's what the antiderivative was. i was saying that was how i was trying to solve the antiderviative but was getting the wrong answer so i needed guidance to go abouts finding the antiderivative correctly. you asked what my initial attempt was which is why i responded with that, i know its wrong but u wanted to know what i did so that's why i showed that
In post #4 you said:
It looks to me like you were claiming that ##x^{e^x + 1}## is the antiderivative of ##x^{e^x}##.
Please don't use "text speak" here at PF. In the rules for this site (https://www.physicsforums.com/threads/physics-forums-global-guidelines.414380/ ), under General Posting Guidelines, it says"
SMS messaging shorthand ("text-message-speak"), such as using "u" for "you", "please" for "please", or "wanna" for "want to" is not acceptable.
i said my "attempt" i never claimed anything?? but anyway nevermind i'll figure it out on my own i just wanted some help and guidance not an argument or a forum of whose wrong whose right i'll delete this shortly
  • · Replies 19 ·
14K
