Find Area of Polygon: Simpler Method?
  • Context: MHB
  • Thread starter Thread starter Blandongstein
    Area Polygon
The discussion revolves around finding the area of a polygon defined by specific vertices. Participants explore different methods for calculating the area, including the Shoelace formula and the use of trapezoids. The focus is on identifying simpler approaches compared to dividing the polygon into triangles.
  • One participant suggests using the Shoelace formula as a method to calculate the area of the polygon, providing the formula and an example calculation.
  • Another participant reiterates the Shoelace method, detailing how to apply it to the specific points given and arriving at a calculated area of 41.5.
  • A different approach is proposed involving the use of trapezoids, where the participant describes calculating the area under a tent-shaped figure and subtracting the areas of lower trapezoids.
Participants present multiple methods for calculating the area, including the Shoelace formula and trapezoidal methods. There is no consensus on which method is simpler or preferable, as different approaches are discussed without resolution.
Some methods may depend on specific assumptions about the polygon's shape or the arrangement of points. The discussion does not resolve which method is the most efficient or straightforward.
Blandongstein
Find the area of the polygon formed by the points (3,5), (5,11), (14,7), (8,3), and (6,6).
I can find the area of the polygon by dividing it into 3 triangles and then finding area of each triangle separately. I want to know if there is any simpler way of doing this.
Mathematics news on Phys.org
Hello DigitalComputer! Such problems are solved using the shoelace formula. If $A_r (x_r , y_r); \ r = 1,2,3, \cdots , n$ be the vertices of a polygon, taken in order then the area of the polygon $A_1 A_2 A_3 \cdots A_n$ is given by
\[\text{area}= \Bigg|\frac{1}{2}\left( \sum_{r=1}^{n-1} \begin{vmatrix}x_i & y_i \\ x_{i+1} & y_{i+1}\end{vmatrix}+\begin{vmatrix}x_n & y_n \\ x_{1} & y_{1}\end{vmatrix}\right) \Bigg|\]
Hi DigitalComputer, :)
To elaborate more on the Shoelace method, suppose you have a set of points, \((x_i,\,y_i)\mbox{ where }i=1,\,2,\,\cdots,\,n\), which are vertices of a polygon. Then the Shoelace formula is,
\[A={1 \over 2}|x_1y_2 + x_2y_3 + \cdots + x_{n-1}y_n + x_ny_1 - x_2y_1 - x_3y_2 - \cdots - x_ny_{n-1} - x_1y_n|\]
where \(A\) is the area of the polygon.
Note that in the Shoelace formula, the positive terms are obtained by the following manner;
The first \(x\) coordinate is multiplied by the second \(y\) coordinate, the second \(x\) coordinate is multiplied by the third \(y\) coordinate and so on. Finally the nth, \(x\) coordinate is multiplied by the first \(y\) coordinate.
And the negative terms are obtained by,
The second \(x\) coordinate is multiplied by the first \(y\) coordinate, the third \(x\) coordinate is multiplied by the second \(y\) coordinate and so on. Finally the first \(x\) coordinate is multiplied by the nth, \(y\) coordinate.
In your case, you have the points, \((3,5),\,(5,11),\, (14,7),\, (8,3)\mbox{ and }(6,6)\). Therefore by the Shoelace formula,
\[A=\frac{1}{2}|(3\times 11)+(5\times 7)+(14\times 3)+(8\times 6)+(6\times 5)-(5\times 5)-(14\times 11)-(8\times 7)-(6\times 3)-(3\times 6)|=41.5\]
Kind Regards,
Sudharaka.
Hello, DigitalComputer!
Find the area of the polygon formed by the points;
. . A (3,5), B(5,11), C(14,7), D(8,3), and E(6,6).
I use trapezoids . . .
Code:
      |           B
      |           o
      |       *   :   E   *
      |      *    :   o     *
      |    *  *   :   : *       o C
      | A o       :   :  *   *  :
      |   :       :   :   o     :
      |   :       :   :   D     :
      |   F       G   H   I     J
First, I find the total area under the tent-shaped figure:
. . trapezoids [tex]ABGF + BCJG.[/tex]
Then I subtract the areas of the three lower trapezoids:
. ..[tex]AEHF + EDIH + DCJI[/tex]
Thank You!
