Find Average Power Given Mass and Velocity
The discussion centers on calculating the average power produced by an engine that accelerates a 1.5×103-kg vehicle from an initial velocity of 13 m/s to a final velocity of 27 m/s over a time period of 12 seconds. The correct approach involves using the formula P = W/t, where W is the work done, calculated as the change in kinetic energy (ΔKE = mvf2 - mvi2). A common mistake noted was using the incorrect final velocity, which led to an erroneous power calculation of 3.4E3 W.
  • Understanding of Newton's laws of motion
  • Familiarity with kinetic energy calculations
  • Knowledge of power and work formulas
  • Basic algebra for solving equations
  • Study the equations of motion to understand displacement calculations
  • Learn about kinetic energy and its applications in physics problems
  • Explore power calculations in different contexts, including mechanical systems
  • Practice problems involving acceleration and force to reinforce concepts
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of power calculations in real-world scenarios.
Snape1830
During 12 s an engine increases the speed of a 1.5×103-kg vehicle from 13 m/s to 27 m/s. Assuming no losses, what average power is the engine producing?
P = W/t
W=FΔx
W=ΔKE
ΔKE=mvf2-mfi2
I tried finding the change in kinetic energy to solve the problem, but it didn't work. I got 3.4E3 W. I'm really lost. I've never done a power problem given only velocity and mass.
You aren't just given velocity and mass. You are given the initial and final velocities, along with the time. From this you can easily calculate the acceleration of the body.
Now that you have acceleration, you also get the force. And displacement should be easy to calculate from the equations of motion. Should be pretty easy from here on...
Thanks! And I realized my problem was that for some strange reason I was using 14 m/s as the final velocity instead of 27 m/s.
Glad to be of help! :smile:
  • · Replies 16 ·
