Find Differential Equation with This Solution
The discussion revolves around finding a differential equation corresponding to the solution y(x) = (x + C)³, with the stipulation that the answer cannot include the constant C. Participants are exploring the relationship between the solution and its derivative.
  • Participants discuss differentiating the given solution and expressing x + C in terms of y(x). There is uncertainty about how to derive the differential equation from the solution.
Some participants have successfully differentiated the solution and reached a form of the derivative. Guidance has been offered regarding checking the correctness of their findings through separation of variables. There is an ongoing exploration of a similar problem involving a different solution format.
Participants are working under the constraint that the differential equation must not contain the constant C. There is mention of a subsequent question that follows a similar format, indicating a sequence of related problems.
AATroop
1. Find a differential equation with the solution y(x) = (x + C)3
The answer cannot contain C)
2. There are no relevant equations.
3. I'm not entirely sure how to do this; I understand that a differential equation has multiple solutions, but for some reason I'm lost on how to find the equation from the solution itself.
Differentiate the solution. See if you can find a way to express x+C in terms of y(x).
Thanks for helping me. I was working on it and I reached \frac{dy}{dx} = 3\times y^{2/3}. I found the derivative and basically just substituted.
And that is exactly correct. If you solve that by separation of variables, you'll get y=(x+C)^3, yes? It's worth a quick check.
Yes, I do. Awesome. Hey, if you don't mind, could you just briefly look over the next question? It's the same format, but y(x) = Cx^3 and I concluded \frac{dy}{dx} = \frac{3\times y}{x}. I just want to make sure that one is correct because the next few questions rely on it.
Thanks again.
Thanks again.
You're welcome. Yes, that's a correct form. Check it the same way as the last one. Separate variables and solve it.
OK, I will. Thank you very much for your help, glad to know I'm finally getting this.
  • · Replies 27 ·
