Find dimension and ker of matrices ?
sid9221
Find dimension and ker of matrices ??
Let V be an F-vector space and (phi:v->v) be an F-linear transformation of V . Define what
it means for a vector v ε V to be an eigenvector of phi and what is meant by the associated
eigenvalue.
This is the form of the question during my calculations I need to calculate:
Now I have from the eigenvalues:
dim(ker()) of a matrix:
1 4 -3
0 0 0
0 0 0
and
1 0 -2/7
0 1 -5/7
0 0 0
Then when the I add up the the dim's I will be able to tell if it is diagonalisable.
Now in this case it is obvious, the dim(ker()) of one is 1 and another is 2. But I can't tell which one is which.
What I mean is the 1st Matrix = 2 and the second Matrix = 1 or viceversa ?
In this case in either way it will add upto 3 and as the original matrix was a 3x3 matrix it is diagonalisable right ?
In essence I don't really understand what dim or ker do ...
I have no clue what you are asking. The title is "Find dimension and ker of matrices" but your first question appears to be about eigenvalues. You have "dim(ker()) of a matrix:" followed by what look like row reduced matrices. What are the original matrices?
You say "Then when the I add up the the dim's I will be able to tell if it is diagonalisable." Tell if what is diagonalisable?
The dimension of the kernel of a matrix tells you whether or not 0 is an eigenvalue and the algebraic dimension but tells you nothing about any non-zero eigenvalues- and does NOT tell you if the matrix is diagonalizable. In particular a row-reduced matrix does not have the same eigenvalues or eigenvectors as the original matrix.
My bad, I shouldn't have given the question in the first place as I just want to know what the resective dims kers are.
1)
what is the dim(ker()) of:
1 4 -3
0 0 0
0 0 0
2)
and what is the dim(ker()) of:
1 0 -2/7
0 1 -5/7
0 0 0
What are the answers to 1) and 2) is all I want to know, also the dims of the above matrices will also be useful.
I know that the answers are 1 and 2, but I'm not sure which one is 1 and which one is 2.
If I am coming across confused, its because I am...sorry
The ranks of both matrices are obvious (just look at the columns). The nullities follow immediately with the rank-nullity theorem.
So for the first one the dim(ker()) is 3-1=2
and for the second one the dim(ker()) is 3-2=1
where 3 is # of columns and 1 and 2 are the ranks respectively ?
Yes, that's correct.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
