Find Eigenspace for Matrix A with 2 Eigenvalues
11 replies · 3K views
UrbanXrisis
matrix [tex]A = \left(\begin{array}{ccc}3&0&0 \\ 0&3&0 \\3&0&0 \end{array}\right)[/tex]
has two real eigenvalues lambda_1=3 of multiplicity 2, and lambda_2=0 of multiplicity 1. find the eigenspace.
[tex]A = \left(\begin{array}{ccc}3-3 &0&0 \\ 0&3-3&0 \\3&0&0-3 \end{array}\right)[/tex]
[tex]A = \left(\begin{array}{ccc}0 &0&0 \\ 0&0&0 \\3&0&-3 \end{array}\right)[/tex]
[tex]A = \left(\begin{array}{ccc}1&0&-1 \\ 0&0&0 \\0&0&0 \end{array}\right)[/tex]
that means the eigenspace for lambda_1 is the column vector [0 1 0] and [1 0 1]
for lambda_2, there will be two different eigenspaces such that...
[tex]A = \left(\begin{array}{ccc}1&0&0 \\ 0&1&0 \\0&0&0 \end{array}\right)[/tex]
I know the answer has two vectors, how do i get two vectors when I have 4 that defines the eigenspace?
Is your eigenvector for [tex]\lambda_3[/tex] not [tex]v_3=(0, 0, k)^T,\;k\in\mathbb{R}[/tex], and for [tex]\lambda_{1,2}[/tex] not [tex]v_{1,2}=(k_1,k_2,k_1)^T,\;k_{1,2}\in\matbb{R}[/tex]?
If
[tex]A = \left(\begin{array}{ccc}1&0&0 \\ 0&1&0 \\0&0&0 \end{array}\right)\left(\begin{array}{c}x \\y\\ z\end{array}\right)= \left(\begin{array}{c}0 \\ 0 \\0 \end{array}\right)[/tex]
Which says x= 0, y= 0. Looks to me like you have just a one dimensional eigen space, spanned by (0, 0, 1)T.
oh right, so three vectors then... [0, 0, 1], [0 1 0] and [1 0 1]
the solution gives 2 vectors, how would I find the eigenspace from 3 vectors?
WHAT solution gives 2 vectors and what eigenspace are you talking about?
Not all texts use that terminology but I think by "eigenspace" you mean the sub-space consisting of eigenvectors haveing the same eigenvalue. In this case, you have two distinct "eigenspaces", one having dimension 2 and the other dimension 1.
Depending on the definition, I think you could also use the general eigenvectors that I gave and form your basis by sticking in ones and zeroes.
HallsofIvy said:
If
yeah right.
If you start with a three dimensional square hermitian matrix, you'll get a 3D eigenspace. period. If you have degenerate eigenvalues - like you do, then you get one unambiguous eigenvector (for the eigenvalue 0) and a 2D eigenspace (corresponding to the degenerate eigenvalue 1) from which you have the freedom of choosing any two linearly independent eigenvectors.
so... there are three vectors the span the space... this is because:
[tex]\lambda_1=3[/tex]
[tex]\left(\begin{array}{c}a \\b \\c \end{array}\right) = s \left(\begin{array}{c}0 \\1 \\0 \end{array}\right) + t \left(\begin{array}{c}1 \\0 \\1 \end{array}\right)[/tex]
[tex]\lambda_1=0[/tex]
[tex]\left(\begin{array}{c}a \\b \\c \end{array}\right) = u \left(\begin{array}{c}0 \\0 \\1 \end{array}\right)[/tex]
so, there are three linearly independent vetors that span the eigenspace
they are: [tex]\left(\begin{array}{c}0 \\0 \\1 \end{array}\right) , \left(\begin{array}{c}0 \\1 \\0 \end{array}\right) , \left(\begin{array}{c}1 \\0 \\1 \end{array}\right)[/tex]
however, my solution is telling me that I need two vectors instead of three such that:
[tex]\left(\begin{array}{c}a \\b \\c \end{array}\right) , \left(\begin{array}{c}d \\e \\f \end{array}\right)[/tex]
Then what was the question? Yes, the three vectors span the space- it is, after all, 3 dimensional.
"my solution is telling me that I need two vectors". Your solution? What solution are you talking about? Your matrix has two distinct eigenvalues, 3 and 0. The eigenspace corresponding to 3 is two dimensional and is spanned by
[tex]\left(\begin{array}{c}1 \\0 \\1 \end{array}\right)[/tex]
and
[tex]\left(\begin{array}{c}0 \\1 \\0 \end{array}\right)[/tex]
The eigenspace corresponding to 0 is one dimensional and is spanned by
[tex]\left(\begin{array}{c}0 \\0 \\1 \end{array}\right)[/tex]
Those three vectors, of course, span all of R3.
oh whoops, I was to find the eigenspace for only [tex]\lambda_1=3[/tex]
so I didnt have to take into account [tex]\lambda_2[/tex]
