Find Force from Collision of 3 Billiard Balls
  • Thread starter Thread starter bob7
    Collision Force
The problem involves three billiard balls, each with a mass of 0.15 kilograms, where one ball collides with another. The original poster seeks to find the average force acting on the first ball during the collision, which lasts for 0.025 seconds, after it changes velocity from 10 m/s to 3 m/s.
  • Participants discuss using momentum to find the average force, with some suggesting the formula for average force as the change in momentum over time. Questions arise regarding the necessity of considering vectors in the calculations and how to properly apply them.
Participants have explored various methods to calculate the average force, including momentum considerations and the application of Newton's laws. Some have provided calculations, while others express confusion about the vector components involved. There is an ongoing examination of the implications of directionality in the force calculations.
There is mention of the initial positions of the balls on an xy-plane, which may influence the vector analysis, but the original poster notes a lack of sufficient information to fully determine the vectors involved in the collision.
bob7
Three billiard balls are placed at rest on a level surface. Each ball has a mass of .15 Kilograms. If Ball 1 (m1) has an initial velocity of 10m/s towards ball 2 (m2), and after the glancing collision ball 1 (m1) moves 3m/s towards ball 3 (m3). Find the average force acting on ball 1 (m1) during the collision if that collision lasts for .025 seconds?
I know you have to use the formula Vf=Vi+at. And then maybe use [tex]\sum[/tex]F=ma to get the force. I am having trouble grasping the vector idea of the problem and combining them. Thanks!
You use momentum. Average force is equal to change in momentum over change in time.
Do I have to worry about vectors with that equation? What would the equation look like exactly? Thanks so much!
Yes, you have to worry about vectors, momentum and force are vectors. The equation is just as I described it (final momentum-initial momentum)/(final time-initial time).
so if I use the formula i get: ((.15*3)-(.15*10))/.025 which gives me 42. But I think this is wrong because of the vectors. I am really confused on how to do this problem with the vectors. Thanks.
Ok, forget about the vectors. They don't give you enough information to determine the vectors. But concentrate on ball 2. It's initially at rest. What's the initial momentum? After the collision it's moving at 3m/sec. What's the magnitude of the final momentum? Take the difference of the two and divide by time.
Ok, the initial mementum of ball 2 is zero. its final momentum is .15*3=.45. Then divide that by time. .45/.025= 18. Would this be that average force that is acting on ball 1 that the problem is looking for? I also know the initial positions of the balls on an xy plane. Ball 1=(-30,0)cm. Ball 2=(0,16)cm. Ball 3=(42,-10)cm. Thanks.
You are still basically using F = ma, the accelerartion is found by a = (v - u) /t
That's the MAGNITUDE of the average force. If you know the positions of the balls, then you do know enough to find the direction as well. Do you need it? If so then repeat the calculation with vectors. The initial momentum is still (0,0) and the final momentum has magnitude .15*3 and is directed along the vector connecting ball 2 with ball 3.
So if 18 is the magnitude of the average force between the two balls, how would I then calculate just the average force acting on ball 1?
Use units. It's not '18', it's 18N. You computed the force ball 1 exerts on ball 2. If you want to find the force ball 2 exerts on ball 1 you might want to look at Newton's third law.
So the final answer is -18N. Thanks so much. Sorry that it took me so long to understand.
How would I include vectors in my answer to make it correct?
If you going to put signs on the force, then you need to describe it's direction. I guess here the minus just means opposite to the direction of the other force. You may be expected to provide vectors.
  • · Replies 18 ·
