Find fourth order differential equation
The fourth order differential equation with the solution y=-9e^(3x)xcos(x) can be derived from its characteristic equation, which must have roots 3+i and 3-i, resulting in double roots. The characteristic equation is expressed as (x^2 - 6x + 10)^2, leading to the differential equation x^4 - 12x^3 + 56x^2 - 120x + 100. The general solution incorporates both the exponential and trigonometric components, utilizing Euler's formula for simplification. This approach effectively combines the derivatives of the solution to find the required equation.
  • Understanding of fourth order differential equations
  • Familiarity with characteristic equations and roots
  • Knowledge of Euler's formula for complex exponentials
  • Ability to compute derivatives of functions
  • Study the derivation of characteristic equations for higher order differential equations
  • Learn about solving differential equations using Euler's formula
  • Explore methods for finding general solutions to homogeneous differential equations
  • Investigate the application of complex numbers in differential equations
Students and educators in mathematics, particularly those focusing on differential equations, as well as professionals seeking to deepen their understanding of advanced mathematical concepts and techniques.
kk1995
Suppose that a fourth order differential equation has a solution y=-9e^(3x)xcos(x).
a. Find such differential equation, assuming that it is homogeneous and has constant coefficients.
b. Find the general solution to this differential equation. x is the independent variable.
I tried to find the derivatives of y (y',y'',y''',y'''').
Then, I placed unknown constants (c1, c2, c3, c4, c5) on each order and made a matrix with each row having coefficients from values containing e^(3x)cosx, e^(3x)xcosx, e^(3x)sinx, and e^(3x)xsinx. I made the columns all have the same order (such as all values from y'' on one column). I also made c1=1 since otherwise the matrix becomes 4*5 and that cannot be solved for the unknown constants. However, this did not work out.
I would sincerely appreciate your help. I mean, I can do those functions that have y=e^rx and y=cos(x), but combination of these makes my head ache.
Have you tried writing cos (x) in terms of complex exponentials?
Think about what the solution whose DE had this characteristic equation$$
(r-a)^2+b^2=0$$would be.
Great! Or course, in order to have e^{3x}cos(x) and e^{3x}sin(x) as solutions, the characteristic equation must have roots 3+ i and 3- i and so must have (x- 3- i) and (x- 3+ i) as factors. In order to have each of those times x as solutions, those must be double roots so the characteristic equation must be of the form (x- 3- i)^2(x- 3+ i)^2= [(x- 3- i)(x- 3+ i)]^2=[(x- 3)^2+ 1]^2= (x^2- 6x+ 10)^2= x^4- 12x^3+ 56x^2- 12x+ 100.
You can get the differential equation itself from that.
"columns"? "matrix"? Too advanced for me!
Thank you all for your replies. All of your replies really helped. The first two replies led me to Euler's formula, while the third one by HallsofIvy led the rest of the problem from the point of getting the values of r using Euler's formula. Note: the -12x should be -120x for the answer, just a point out at a typo. :)
  • · Replies 25 ·
