Find Invariant Lines for Matrix Transformations | y=mx Form | Solutions
  • Thread starter Thread starter Gregg
    Invariant Lines
5 replies · 3K views
Gregg
Find all invariant lines, of the form y=mx for the matrix transformation.
a) [itex]\left(<br /> \begin{array}{cc}<br /> 5 & 15 \\<br /> -2 & 8<br /> \end{array}<br /> \right)[/itex]
b) [itex] \left(<br /> \begin{array}{cc}<br /> 3 & -5 \\<br /> -4 & 2<br /> \end{array}<br /> \right)[/itex]
[itex]\left(<br /> \begin{array}{cc}<br /> 5 & 15 \\<br /> -2 & 8<br /> \end{array}<br /> \right)\left(<br /> \begin{array}{c}<br /> x \\<br /> \text{mx}<br /> \end{array}<br /> \right)=\left(<br /> \begin{array}{c}<br /> 5x+15\text{mx} \\<br /> -2x-8\text{mx}<br /> \end{array}<br /> \right)[/itex]
And for it to map onto the line, this is probably the wrong bit.
[itex] \left(<br /> \begin{array}{c}<br /> 5x+15\text{mx} \\<br /> -2x-8\text{mx}<br /> \end{array}<br /> \right)=\left(<br /> \begin{array}{c}<br /> x \\<br /> \text{mx}<br /> \end{array}<br /> \right)[/itex]
[itex]x=5x+15mx \Rightarrow 4=15m \Rightarrow m=\frac{4}{15}[/itex]
I'll stop there because I know it's wrong. So what am I doing wrong, and what false assumptions have been made?
I think if I put y=m(5x+15mx) i'll get the answer but I don't see the logic behind that at all even though it's been explained to be, in my head you could be going y=m(m(m(m(m(m(m(m... forever if you did that.
Edit: Nope didn't work.
I think that what you are asked to do here is to find all vectors (x, y) for which multiplying on the left by your matrix produces a new vector (kx, ky) that is a multiple of the input vector.
I don't believe that there are any for your first matrix, but I believe there are two for your second matrix.
If my understanding of this problem is correct, it is setting you up for a discussion of eigenvectors. An eigenvector is a nonzero vector x such that Ax = kx. IOW, multiplication of x by the matrix A produces a vector that is a scalar multiple of the input vector; i.e., a vector that has the same direction (possibly pointing the other direction) and therefore, has the same slope.
error in the question, It supposed to be {{5,15},{-2,-8}} not +8!
edit: yes you're right it's the preamble to the chapter on eigenvectors and eigenvalues, diagonalisation etc. It is still troubling me though, how I can find lines that map to themselves (invariant lines) such as y=mx or y=mx+c, but eigenvectors are fine. It's just this that's confusing me. An example would be good. Or the solution to these?
Saying a line is invariant does NOT mean that points are invariant. The line y= mx is invariant as long as a point, (x, mx) is mapped into something of the form (a, ma), not necessarily with a= x.
You do not need
[itex]\left(\begin{array}{c} 5x+15\text{mx} \\ -2x-8\text{mx}\end{array}\right)=\left(\begin{array}{c} x \\ \text{mx}\end{array}\right)[/itex]
rather you need
[itex]\left(\begin{array}{c} 5x+15\text{mx} \\ -2x-8\text{mx}\end{array}\right)=\left(\begin{array}{c} a \\ \text{ma}\end{array}\right)[/itex]
for some number a. More specifically, you need to look at
[tex]\frac{-2x-8mx}{5x+ 15mx}= \frac{-2-8m}{5+ 15m}= \frac{ma}{a}= m[/tex]
Solve that for m.
You do not need
rather you need
Solve that for m.
Ok so,
[itex] \left(<br /> \begin{array}{cc}<br /> 5 & 15 \\<br /> -2 & -8<br /> \end{array}<br /> \right)\left(<br /> \begin{array}{c}<br /> x \\<br /> \text{mx}<br /> \end{array}<br /> \right)=\left(<br /> \begin{array}{c}<br /> 5x+15\text{mx} \\<br /> -2x-8\text{mx}<br /> \end{array}<br /> \right)=\left(<br /> \begin{array}{c}<br /> x' \\<br /> \text{mx}'<br /> \end{array}<br /> \right)[/itex]
[itex]mx'=m(5x+15mx)[/itex]
[itex]-2x-8mx=m(5x+15mx)[/itex]
[itex]\Rightarrow 15m^2+13m+2=0[/itex]
[itex]m=-\frac{1}{5},-\frac{2}{3}[/itex]
For your 2nd problem, calculate Ax, with x = (-5/4, 1)T. You should get a vector that is a constant multiple of x. In fact, when you multiply Ay, where y is any multiple of the vector I showed for x, you'll get another vector that is the same constant multiple of y. This shows that for this matrix A, the vector (-5/4, 1) is special in the sense that the product of A and this vector is another vector whose only difference is that it is longer than (-5/4, 1). For this matrix, there is another vector that behaves the same way.
