Find Laplace Transform of (e^t + 2t^4 - cos (4t) + 10)
The discussion focuses on finding the Laplace Transform of the expression (e^t + 2t^4 - cos(4t) + 10). Participants emphasize the linearity property of the Laplace Transform, allowing the problem to be broken down into smaller components: L{e^t}, 2L{t^4}, -L{cos(4t)}, and L{10}. The final transformed expression is confirmed as 1/(s-1) + 2*4!/s^5 - s/(s^2+16) + 10/s. Additionally, users discuss solving initial value problems using Laplace transforms, providing detailed calculations and corrections for various examples.
  • Understanding of Laplace Transform properties and definitions
  • Familiarity with linear differential equations
  • Knowledge of initial value problems in calculus
  • Ability to perform algebraic manipulations and partial fraction decomposition
  • Study the linearity property of the Laplace Transform in depth
  • Learn how to solve initial value problems using Laplace Transforms
  • Explore the use of Laplace Transform tables for common functions
  • Practice partial fraction decomposition techniques for Laplace Transform inverses
Students and professionals in engineering, mathematics, and physics who are working with differential equations and seeking to understand the application of Laplace Transforms in solving initial value problems.
Lucy77
Find Laplace Transform of...
Thank you
Remember that the Laplace Transform is a linear operator. That means that you can treat each one of the four terms as a separate little problem and then add them all back up at the end.
Other than that, just apply the definition of the Laplace Transform or look at a table of transforms.
cookiemonster
But I don't know how to apply what you said to this problem. Can you please show me how?
He meant that when calculating:
L{et+2t4-cos(4t)+10},
you can use the fact that the Laplace operator is linear to get:
L{et}+2L{t4}-L{cos(4t)}+L{10}.
That is, you can use linearity to turn your big problem into 4 small ones.
edit: fixed a superscript bracket
Is this right
e
1/(s-1) + 2* 4!/s^5- s/(s^2+16) + 10/s
am I done?
Thanks
I get the same thing.
Hi I just did two more Laplace problems can anyone please tell me if they're correct.
1.Solve the following intital value problem using the method of Laplace transforms.
y'' - 10y' + 25y = e^5t y(0)=0 y'(0)=0
y"- 10y'+ 25y= e5t becomes -y'(0)- sy(0)+ L(y)- 10f(0)+ 10L(y)+ 25L(y)= L(e5x).
Since y'(0)= y(0)= 0, this is just 34L(y)= L(e5x) so that
L(y)= L(e5x)/34 and, since L(cf)= cL(f) for any constant c,
y(x)= e5x/34.
2.Find Laplace transform inverse
L^-1 (4/s + 1/(s-1)^2 + (3s-16)/(s^2+64)
4 +te^t + 3cos8t + -2sin8t
Thank you
Number 2 is right.
Number 1 isn't.
L \{y^{\prime \prime}\} -10L \{y^\prime\} + 25L \{y\} = L \{e^{5t}\}
s^2Y(s) -sy^\prime(0) - y(0) -10(sY(s) -y(0)) +25Y(s)= \frac{1}{s-5}
s^2Y(s) -10sY(s) +25Y(s)= \frac{1}{s-5}
Y(s)(s^2 -10s +25)= \frac{1}{s-5}
Y(s)(s-5)^2= \frac{1}{s-5}
Y(s)= \frac{1}{(s-5)^3}
L^{-1}\{Y(s)\}=L^{-1} \{\frac{1}{(s-5)^3}\}
y(t)=\frac{1}{2}t^2e^{5t}
The above should be correct.
Well anyway, good Luck and I hope it helps.
Hi,
I have a couple of more that I did. Could someone please check and see if these are right.
1. FIND THE LAPLACE Transform of the unknown solution function for the following initial value problem:
y" + 4y' - 5y = te^(t), y(0) = 1, y'(0)=0
(Do Not actually find the function, only its transform. Then, without carrying out the steps, inidicate briefly how you would proceed to find the solution function.)
s^2L = s + 4sL - 4 - 5L = Lte^t = 1/(s-1)^2
(s^2 + 4s - 5)l = 1/(s-1)^2 + s +4 = (s^3+ 2s^2-7s+4)/(s-1)^2
simplify
= (s-1)^2(s+4)/(s-1)^3(s+5) = s=4/(s-1)(s+5)
at this point I would do partial fractions.
2.Find Laplace Inverse
L^-1 { (s+10)/(s^2+8s+20)}
s+10)/(s^2+8s+20) = (s+10)/(s^2+8s+16+4) = (s+10)/((s+4)^2+4)
(s+10)/((s+4)^2+4) = (s-(-4))+ 3*2)/(s-(-4))^2+2^2) = (s-(-4)/((s-(-4))^2+2^2) + 3*2/(s-(-4)+2^2)
The Inverse Laplace Transform of that is
e^-4t cos 2t + 3 e^-4t sin 2t.
3. Find Laplance Transform
Find L (f(t)} where f(t) = e^-t (0 <= t < 5)
-1 (t >= 5)
For t in [0,5) the solution would be Int((e^{-t})(e^{-st},0,infinity,dt)=Int(e^{-t(s+1)},0,infinity,dt}=-e^{-t(s+1)}/(s+1)|0,infinity) = 1/(s+1).
For t in [5,infinity) Int(-1*e^{-st},0,infinity,dt} =(1/s)e^{-st}|0,infinity)=-1/s.
In piecewise notation you write L(f(t))={1/s, 0 <= t < 5 and -1/s, t >= 5}
4. Find Laplace Inverse of
L^-1 { (3s-4)/s(s-4) }
so
3s-4)/s(s-4) = A/s + B/(s-4)
s*(3s-4)/(s(s-4)) = A + B*s/(s-4)
Taking limit ( s to 0)
-4/-4 = A
A =1
And
(s-4)*(3s-4)/(s(s-4)) = A*(s-4)/s + B
Taking limit ( s to 4)
8/4 = B = 2
so
(3s-4)/s(s-4) = 1/s + 2/(s-4)
Thank you
  • · Replies 17 ·
