Find mass of an object hanging on string
  • Thread starter Thread starter angi-18
    Mass String
To find the mass of an object hanging on a string, the relevant formula involves analyzing the forces acting on the masses. For two bodies A and B connected by a string over a pulley, the net force on mass B can be expressed as F_net = m_B * g - T = m_B * a, while for mass A, it is T - m_A * g = m_A * a. By eliminating the tension T from these equations, the relationship between the masses can be derived. Specifically, the formula α = (m_B - m_A) / (m_B + m_A) * g can be used to find mass B when given the acceleration and mass of A. Understanding the forces and applying Newton's second law is key to solving this problem.
angi-18
please tell me how to find the mass of an object which is hang on the string?
I mean what would be the formula ?
i am also writing here my numerical question...
Q:two bodies A and B are attached to a string which passes over a pulley so that two bodies hang vertically.if the mass of body A is 4.8 kg find the mass of body B which moves down with an acceleration of 0.2m/s.s.(g=9.8m/s.s)
Make a diagram of the situation.
Look carefully at mass B. How many forces act on mass B?
no force is acting on mass B the formula given in our textbook is:
α=(mB-mA/mB+mA) x g
i don't know how to arrange it to find the mass B...:confused:
We are trying to show HOW to get that formula.
Look at mass B. It has the Earth pulling it down - that is the weight mB x g of mass b - and the string pulling it up by a tension T.
Now use Fnet = ma for mass B.
Fnet = ma ...for mass B
mBg - T = mBa
Fnet = ma ....for mass A
T - mAg = mAa
If the tension T is eliminated from the above two equations then one gets the equation required.
  • · Replies 47 ·
  • · Replies 28 ·
