Find Optimum Angle of Launch: Calculate Velocity of Ball from Catapult
  • Thread starter Thread starter monkeyguy31
    Velocity
The discussion revolves around calculating the velocity of a ball launched from a catapult to determine the optimum angle of launch. The scenario involves a ball fired from a height of 0.5m, landing 1.45m away at an initial angle of 45°.
  • The original poster attempts to use the equation v^2 = u^2 + 2as to find the velocity but questions the validity of their results based on observed flight time. Some participants question the relevance of the stated launch angle and the completeness of the provided data.
Participants are exploring the relationship between launch angle and distance traveled, with some suggesting that additional data may be necessary for accurate calculations. The original poster acknowledges an error in unit conversion, which may have affected their calculations.
The original poster is conducting an experiment measuring distances for various launch angles from 20° to 70°, with 45° being noted as the optimum angle in the absence of air resistance.
monkeyguy31
Hello, i have to work out the velocity of a catapult which i had to do for my AS Quality of measurement coursework where I'm trying to find the optimum angle of launch.
A ball is fired from a catapult 0.5m above the ground, the ball hits the ground 1.45m away, the angle of launch is 45°. Calculate the velocity of the ball.
v^2= u^2 + 2as
Attempted it by plugging numbers into that equation but comes up with 37.6 m/s, whilst watching the catapult fire it took a few seconds to land so it couldn't be that fast, although after using Time = Distance/Speed it appears to be 3.9s which could be right but I'm not sure. Am I using the wrong equation i need to compare this to other angles but not sure what equation to use with angles.
Sorry, are you trying to find out the optimum angle of launch? Because you stated an angle in section one, the known data.
I was using 45° as an example, whilst doing the experiment I measured the distance traveled for 11 angles at 5° intervals from 20° to 70°. As 45° is the optimum angle excluding air resistance I'm going to work that one out first and compare to other angles. Should of included more detail. :smile:
How did you get the to answer of 3.9 seconds and 37.6 ms-1? From what you have given me in section one (the known data) I can only find the horizontal distance and the launch angle, and I cannot understand how you find your given answer from that. Is there a missing piece of data that you might have forgotten?
I worked it out for myself, noticed i was making a huge error by putting the displacement in cm instead of metres, silly me. :smile:
  • · Replies 39 ·
  • · Replies 36 ·
11K
