Find relative speed of fast moving partical with dilated time
The discussion revolves around calculating the speed of muons relative to Earth and understanding time dilation in special relativity. Participants clarify that the muon's proper lifetime is 2.197 microseconds, and due to time dilation, it can travel 10 km before decaying, which leads to the need for calculating its speed. The key point is that while the muon experiences a short proper time, the distance it travels appears length-contracted in its rest frame, ensuring it does not exceed the speed of light. Participants express confusion about the relationship between proper time, dilated time, and velocity calculations, ultimately arriving at a plausible speed of approximately 299,350,496 meters per second. The discussion highlights the complexities of relativity and the importance of understanding frame-dependent measurements.
akennedy
The muon is an unstable elementary particle that decays via a weak-force
interaction process into an electron and two neutrinos. The life time of muons in their rest
frame is 2:197 s  2:197106 s. Nuclear reactions in the upper atmosphere, precipitated by
the impact of highly energetic cosmic rays, generate fast-moving muons about 10 km above sea
level. Some of these particles are detected in labs at about sea level. This is possible because
the life time of muons moving with respect to the Earth's surface is dilated.
(i) Estimate the muons' speed relative to Earth from the fact that they travel 10.0 km between
their point of creation in the atmosphere until seen to decay in ground-based labs.
(ii) The proper distance traveled by the muons considered in part (a) is 10.0 km. Calculate
the length of this distance as it would be measured in the muons' rest frame. Explain
how your result, if interpreted using Galilean relativity, would be at odds with nding
cosmic-ray muons at the Earth's surface.
gamma = 1/SQRT(1-v^2/c^2)
Time = gamma*proper time
Honestly I'm clueless. I am really struggling with relativity but here's my current understanding of the problem (i). The muon is traveling at high speeds so it experiences time dilation and is able to travel to the surface of the Earth without decaying.
The proper time would be the time as measures on the Earth as it is, for all purposes, at rest right?
I'm having trouble understanding the whole dilation aspect... If the particle experiences time dilation does that mean it's only undergone that time above to travel 10KM? Wouldn't that mean it was traveling faster than c?
Is the 2.197x10-6 the proper time or the dilated time? :|
Sorry I really don't know where to start.
I guess my biggest problem is this. The particle must have only experienced 2.197x10-6 seconds but then it's traveling faster than the speed of light in it's frame. Please someone help me understand this lol
I don't know how to solve for v without having both the proper time and dilated time :|
I tried using the t = gamma*tp formula, but replaced v in gamma with 10000/tp and tried to solve for tp but couldn't get anywhere. Can someone please give me a hint?
Right.
You have two events: the muon's creation and the muon's decay. The proper time would be the time measured by a clock traveling along with the muon between the two events.
I'm having trouble understanding the whole dilation aspect... If the particle experiences time dilation, does that mean it's only undergone that time above to travel 10KM? Wouldn't that mean it was traveling faster than c?
In the muon's rest frame, only 2.197 μs elapses between its creation and decay. What you're forgetting is that in the muon's rest frame, the 10-km distance is length-contracted. When you take the length-contracted distance and divide it by 2.197 μs to calculate the muon's speed, you'll get a result less than ##c##.
Likes 1 person
Right, that makes sense. So the proper time is the given time, and I need to find the dilated time to calculate the velocity?
Am I right in that if I find this dilated time, in the Earth's frame, and use it to divide 10,000 I'd get the velocity?
If so, should I just use the t = tp*gamma formula to solve for t while replacing v with 10000/t? Or am I missing something here.
Thanks a lot for your help.
I ended up with 299350496 metres per second. That sounds about right, at least it isn't impossible lol. Thanks a lot buddy.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
