How Do You Calculate the Slant Height of a Cone?
  • Context: MHB
  • Thread starter Thread starter gazparkin
    Cone Height
The discussion focuses on calculating the slant height of a cone given its total surface area and radius, as well as determining the circumference of its base using the slant height and curved surface area. The formula for total surface area is established as \(A_T = \pi r s + \pi r^2\), allowing for the calculation of slant height \(s\) using \(s = \dfrac{A_T - \pi r^2}{\pi r}\). Additionally, the relationship between curved surface area and radius is clarified with \(A_L = \pi r s\), leading to the formula for circumference \(C = 2\pi r\).
  • Understanding of cone geometry and properties
  • Familiarity with surface area formulas for cones
  • Basic algebra for solving equations
  • Knowledge of circular geometry for circumference calculations
  • Study the derivation of the total surface area formula for cones
  • Learn how to apply the Pythagorean theorem in cone problems
  • Explore the concept of developable surfaces in geometry
  • Practice problems involving slant height and surface area calculations
Students studying geometry, educators teaching cone properties, and anyone interested in mastering calculations related to conical shapes.
gazparkin
Hello,
Could anyone help me understand the steps on the below questions?
A cone has a total surface area of 300π cm² and a radius of 10 cm. What is its slant height?
A cone has a slant height of 20 cm and a curved surface area of 330 cm2. What is the circumference of its base? I'd really like to know what steps I need to take to get to the answer on these.
Thank you in advance :-)
Mathematics news on Phys.org
gazparkin said:
Hello,
(1) total surface area = lateral surface area + base area
$A_T = \pi r s + \pi r^2$, where $s$ is the slant height and $r$ is the base radius
solving for $s$ $\implies s = \dfrac{A_T - \pi r^2}{\pi r}$
(2) assuming "curved surface area" is the lateral surface area ...
$A_L = \pi r s \implies r = \dfrac{A_L}{\pi s}$
use the formula for a circle's circumference to finish
Suppose a cone (minus the circular bottom) has radius r and slant height s. Cut a slit along the slant and flatten it (Unlike a sphere a cone can be flattened. it is a "developable surface."). It will form part of a circle with radius h. That entire circle has radius h so area \pi h^2 and circumference 2\pi h. But the base of the cone had radius r so circumference 2\pi r. The cone is only \frac{2\pi r}{2\pi h}= \frac{r}{h} of the entire circle so has area \frac{r}{h}\pi h^2= \pi rh.
  • · Replies 30 ·
9K
  • · Replies 25 ·
