Find speed of quasar from observed and actual wavelength readings
Astronomers calculated the speed of a quasar based on observed and actual wavelength readings, finding a feature at 442 nm corresponds to 581 nm in the quasar's rest frame. The observed frequency was calculated as 6.79e14 Hz, while the actual frequency was 5.16e14 Hz. The correct formula to use for calculating the speed of the quasar is the relativistic Doppler effect, specifically the equation fobs = (1 + u/c) femitted, which accounts for the quasar approaching the observer. The final calculated speed of the quasar was determined to be 0.267c.
  • Understanding of the Doppler effect in astrophysics
  • Familiarity with frequency and wavelength conversions
  • Knowledge of the speed of light (c) and its implications in relativistic physics
  • Ability to apply the relativistic Doppler effect formula
  • Study the relativistic Doppler effect in detail
  • Learn about frequency and wavelength relationships in astrophysics
  • Explore the implications of relativistic speeds on astronomical observations
  • Practice calculations involving the speed of light and relativistic formulas
Astronomers, physics students, and anyone interested in understanding the dynamics of distant celestial objects and their observed properties.
Sarial
1. Astronomers on Earth observe a feature at 442 nm in the spectrum of a distant quasar. However, it is known that this feature corresponds to 581 nm in the rest frame of the quasar. Calculate the speed of the quasar. Enter your answer as a fraction of the speed of light, positive if the quasar is approaching, negative if it's receding.
I used
It was easier for me to think about this in terms of frequency than wavelength, so I converted the wavelengths into frequency by using
c = speed of light
L = lambda, wavelength
f = frequency
u = speed of source
c/L = f
So 3e8/442e-9 = 6.79e14
3e8/581e-9 = 5.16e14
So the observed frequency is 6.79e14 Hz and the actual frequency is 5.16e14 Hz.
fobs=(1-u/c)femitted
6.79e14 = (1-u/c)(5.16e14)
1.316 = 1-u/c
.316=-u/c
-.316c=u
Now, this isn't right. I'm using (1-u/c) versus (1+u/c) because the relative speed of the object is negative if they're approaching, and the wavelength is getting blueshifted, so they're moving towards each other. However, that produces a negative answer, and the question states to enter a positive answer if they're moving towards each other.
Anyone see any mistakes in my work?
Thanks a lot in advance~
Bump? :( I don't know where else to go with this
Bump. Due at 10 PM EST tonight
It's simply that your equation is wrong. The quasar and the observer are moving towards each other, so the ratio should be 1+v/c, not 1-v/c. Your calculation, which is correct, also shows that.
I tried +.314 and still no luck. I must be making a tiny mistake somewhere, and I just can't find it.
Suppose that your calculation is correct. We all know that they are approaching each other at +0.314c. But in your formula, the minus sign means that v is the speed at which they are going away from each other. Therefore, that v is negative means that they are approaching each other, which matches the expected phenomenon.
I believe the +/- discrepancy, but the .314 apparently isn't right either :\
Ohhh. That could be it. I'll try that soon, thank you. You should use the relativistic formula for .10c+?
It depends, but generally, yup :)
Yes! Thank you. I knew it was something small like that. .267c was the right answer, and using gamma sorted it all out!
Case closed :P
  • · Replies 22 ·
