Find T(t) at (1,0,0) when r(t)=<cos(t),sin(t),ln(cos(t))>
  • Thread starter Thread starter thegoodfight
The discussion focuses on finding the tangent vector T(t) and the normal vector N(t) at the point (1,0,0) for the parametric curve defined by r(t) = . The derivative dr/dt is calculated as <-sin(t), cos(t), -tan(t)>, and the magnitude ldr/dtl is determined to be sec(t). The final expression for T(t) is derived as T(t) = <-tan(t), 1, -sin(t)/cos^2(t)>. The correct parameter value t to evaluate T(t) at the specified point is established as t = 0.
  • Understanding of parametric equations in vector calculus
  • Knowledge of derivatives and their applications in vector functions
  • Familiarity with trigonometric functions and their properties
  • Basic understanding of the concepts of tangent and normal vectors
  • Study the derivation of tangent and normal vectors in vector calculus
  • Learn about the implications of parametric equations in 3D space
  • Explore the properties of trigonometric functions, particularly in calculus
  • Investigate the applications of T(t), N(t), and B(t) in physics and engineering
Students and educators in calculus and vector analysis, particularly those focusing on parametric curves and their geometric interpretations.
thegoodfight
r(t)=<cos(t),sin(t),ln(cos(t))> Find T(t) (and N(t)) at (1,0,0)
T(t)=(dr/dt)/ldr/dtl
dr/dt = <-sin(t),cos(t),-tan(t)>
ldr/dtl = (sqrt)((-sin(t))^2+(cos(t))^2+(-tan(t))^2) = sec(t)
therefore T(t)= (<-sin(t),cos(t),-tan(t)>)/sec(t) = <-tan(t), 1, -sin(t)/cos^2(t)>
The problem I'm having is determining which value for the given point do I use to evaluate T(t) (and thereby N(t) and B(t)). How do I tell which value is best or is there a specific value from the point that is always used? Usually it's easier to tell if one of the values is given in radians, such as pi/2. Thanks for any help you can give me.
You use the t value that gives you r(t) = (1,0,0). What t would that be?
Ok! That makes a LOT more sense now. So t = 0 so that way the vector shows the point (1,0,0). Thanks a lot. Something small like finding this out makes it make so much more sense now.
9K
