Find the convective heat transfer coefficient
4 replies · 11K views
Carlo09
Ok it's my first time here and I was hoping to get some help on some questions I have been given. I am a first year chem eng and I'm finding the work pretty hard so any help at all will be useful, thanks.
I need to find the convective heat transfer coefficient, h for petrol using this equation:
hD/Lamdaf = 0.37 Re^0.6
so using information I am given:
D = 3mm = 0.003m
Lamdaf (thermal conductivity) = 0.145 w/m k
(M)=viscosity = 0.0006 Pa s
u=Velocity of petrol = 19.2 m/s
P=density of petrol = 737.22 kg/m^3
Ok so to calculate Re I am using: Dup/(M) = (0.003*19.2*737.22)/0.0006 = 70773.12
Is this correct so far?
Then I put this back into the equation and rearrange for h which I get to be =14533.475! w/m^2 k
Is this correct because it seems very big to me! if not please can someone point me into the right direction... thank you very much!
I'm assuming this is flow through a pipe? You seem to have run the numbers correctly, and that convective coefficient doesn't seem out of the realm of possibility to me.
Your Reynold's number does seem a bit low, I caluclated 126,500 but I might have used some fuzzy numbers in there.
It says the temperature of petrol is monitored by a thermocouple in the flow, so I'm guessing pipes?
How did you get your Re at that value? Have i used the wrong values to calculate it?
Thank you for your help
I calculated the Reynold's number using the equation:
[tex]Re_{D}=\frac{\rho*u_{m}*D}{\mu}[/tex]
where
[tex]\rho=719\frac{kg}{m^{3}}[/tex]
[tex]u_{m}=19.2\frac{m}{s}[/tex]
[tex]D=3mm[/tex]
[tex]\mu=3.3*10^{-4}Pa*s[/tex]
With these inputs the Reynold's number works out to 125,200.
So since I was a third of the way there anyway, I went ahead and tried calculating the convective heat transfer coefficient. The equations I used are out of my heat transfer textbook, "Introduction to Heat Transfer" by Incropera and DeWitt.
The answer I got was h= 30,950 W/m^2*K
I attached the MathCAD sheet I used to calculate it rather than trying to type it out in Latex.
