Find the coordinates of $P$
  • Thread starter Thread starter Chris L T521
The discussion focuses on finding the coordinates of point $P$ within a square defined by vertices $P_1(0,1)$, $P_2(1,1)$, $P_3(1,0)$, and $P_4(0,0)$. The midpoints $P_5$, $P_6$, and $P_7$ are calculated recursively, leading to the equations $\frac{1}{2}x_n + x_{n+1} + x_{n+2} + x_{n+3} = 2$ and $\frac{1}{2}y_n + y_{n+1} + y_{n+2} + y_{n+3} = \frac{3}{2}$. Ultimately, the coordinates of point $P$ are derived as $P\left(\frac{4}{7}, \frac{3}{7}\right)$ when $b=h=1$.
  • Understanding of mid-point formulas in geometry
  • Familiarity with recursive sequences and their convergence
  • Knowledge of characteristic polynomials and their roots
  • Basic algebraic manipulation and equation solving
  • Explore the properties of linear homogeneous recurrence relations
  • Study convergence criteria for sequences and series
  • Learn about the application of mid-point formulas in various geometric contexts
  • Investigate the implications of characteristic roots in recursive sequences
Mathematicians, educators, and students interested in geometric sequences, recursive algorithms, and convergence analysis will benefit from this discussion.
Chris L T521
MHB
Thanks again to those who participated in last week's POTW! Here's this week's problem!
Problem: Starting with the vertices $P_1(0,1)$, $P_2(1,1)$, $P_3(1,0)$, $P_4(0,0)$ on a square, we construct further points as shown in the figure below: $P_5$ is the midpoint of $P_1P_2$, $P_6$ is the midpoint of $P_2P_3$, $P_7$ is the midpoint of $P_3P_4$, and so on. The polygonal spiral path $P_1P_2P_3P_4P_5P_6P_7\ldots$ approaches a point $P$ inside the square.
a) If the coordinates of $P_n$ are $(x_n,y_n)$, show that $\frac{1}{2}x_n + x_{n+1} + x_{n+2} + x_{n+3} = 2$ and find a similar equation for the $y$-coordinates.
b) Find the coordinates of $P$.
This week's problem was correctly answered by MarkFL. You can find his answer below.[sp]Let's generalize a little to use a rectangle of base $b$ and height $h$ instead of a unit square, hence:
$$P_1=(0,h),\,P_2=(b,h),\,P_3=(b,0),\,P_4=(0,0)$$
a) We see that both $x_n$ and $y_n$ may be found using the recursive algorithm:
$$u_{n+4}\equiv\frac{u_{n}+u_{n+1}}{2}$$
This follows from the mid-point formula. Now, for such an algorithm, consider the following sum:
$$u_{n+4}+2u_{n+5}+2u_{n+6}+2_{n+7}=k$$
Using the algorithm, we have the following:
$$u_{n+4}+u_{n+1}+u_{n+2}+u_{n+2}+u_{n+3}+u_{n+3}+u_{n+4}=k$$
Collecting like terms, we find:
$$u_{n+1}+2u_{n+2}+2u_{n+3}+2u_{n+4}=k$$
From this, we may therefore conclude that for any $n$, we have:
$$u_{n}+2u_{n+1}+2u_{n+2}+2u_{n+3}=k$$
Where the parameter $k$ may be determined from the first 4 values of the sequence.
For the sequence $x_{n}$, we find:
$$x_{1}+2x_{2}+2x_{3}+2x_{4}=4b\implies \frac{1}{2}x_{n}+x_{n+1}+x_{n+2}+x_{n+3}=2b$$
For the sequence $y_n$, we find:
$$y_{1}+2y_{2}+2y_{3}+2y_{4}=3h\implies \frac{1}{2}y_{n}+y_{n+1}+y_{n+2}+y_{n+3}=\frac{3h}{2}$$
Using the data given for this problem:
$$b=h=1$$
we have:
$$\frac{1}{2}x_{n}+x_{n+1}+x_{n+2}+x_{n+3}=2$$
$$\frac{1}{2}y_{n}+y_{n+1}+y_{n+2}+y_{n+3}=\frac{3}{2}$$
b) Since the coordinates are converging to one value, namely $P(x,y)$, we may write:
$$x+2x+2x+2x=7x=4b\implies x=\frac{4b}{7}$$
$$y+2y+2y+2y=7y=3h\implies y=\frac{3h}{7}$$
Hence:
$$P(x,y)=\left(\frac{4b}{7},\frac{3h}{7} \right)$$
$$b=h=1$$
we have:
$$P(x,y)=\left(\frac{4}{7},\frac{3}{7} \right)$$ [/sp]
edit by MarkFL (with permission given by Chris L T521):
The question about convergence of the sequence was brought up by one of our members. You can find the proof of convergence below:
[sp]Consider the linear homogenous recurrence obtained from the mid-point formula:
$$u_{n+4}=\frac{u_{n}+u_{n+1}}{2}$$
We may write this as:
$$2u_{n+4}=u_{n+1}+u_{n}$$
From which, we obtain the characteristic polynomial:
$$2r^4-r-1=(r-1)\left(2r^3+2r^2+2r+1 \right)=0$$
The characteristic roots, the irrational of which I will approximate, are given by:
$$r\approx1,\,-0.647798871261042,\, -0.176100564369479\pm0.860716618623568i$$
Hence, the closed form can be approximated with:
$$u_{n}\approx k_1+k_2(-0.647798871261042)^n+k_3(0.878546815113479)^n \sin\left(n\theta+k_4 \right)$$
We see then that we must have:
$$\lim_{n\to\infty}u_{n}=k_1$$
That is, the sequence $u_{n}$ must converge to some fixed value.[/sp]
