A Find the Equation of a Line (not simple)
  • A
  • Thread starter Thread starter Samky
    Line
The discussion revolves around finding the equation of a line traced by a point moving towards another point on a Cartesian plane, where one point oscillates vertically and the other moves horizontally. Participants clarify the motion involved, emphasizing that while the speed of the oscillating point remains constant, its direction changes, creating a complex trajectory. There is a suggestion to consider the problem in terms of vectors and derivatives, with hints provided for formulating the motion equations. The conversation highlights the challenge of visualizing the motion and the need for analytical or numerical methods to derive a solution. Ultimately, the goal is to understand the underlying mechanics of the motion to formulate the equation accurately.
Samky
TL;DR Summary
Old puzzle -- I need help on how to approach
An old puzzle that was given to me long ago. I don't know how to approach this problem, any help is appreciated. I'm removing some specifics because I don't want it solved for me, I want to know how to approach it. Feel free to solve a simplified version if that helps you explain it to me.
Imagine two points on a standard Cartesian plane. Point one at the origin, and point 2 somewhere on the x axis. Now:
1) Point 1 moves along the y-axis at constant velocity and with period T
2) Point 2 moves at constant velocity and always directly at point 1
3) The velocities and period are such that the two points will meet at the origin
By tracing the path of point 2, we have a line.
Find the equation of this line.
Simplified version example:
Point 2 starts at (10, 0). Point 1 moves at 10 meters per second. Point 1 moves up 10 meters then down 10 meters. After two seconds they meet at (0, 0)
Mathematics news on Phys.org
You get a tractrix, or two combined tractrices in this case. It has analytic expressions for the arc length, so maybe you can find an analytic solution for the full problem. If not, numerical methods will find an approximation.
Likes phinds
Thanks a lot, I'll look into that!
I wrote some MATLAB code to get a good approximation, so I have some graphs and numbers, but that's sort of cheating. I'm sure a mathematician could solve the original problem in closed form but I have no clue how to begin... but this should help me out, thanks again.
It's probably a good idea to call this a curve and not a line.
Likes phinds
How can a velocity be both constant and periodic unless it is merely constant?
I'm confused by that too
Sorry, I mean speed. The magnitude doesn't change but the direction does. It's basically a one dimensional oscillation that creates a two dimensional oscillation.
I still can't picture the motion. An object can travel in a circle with constant speed, and if you take one component of its motion then you will have a one-dimensional oscillator. However, if you have a one-dimensional oscillator it must turn around 180 degrees at its maximum displacement. To do that, it must get to zero speed before turning around.
Do you mean it has a constant angular frequency?
It's an up/down motion with constant speed and alternating sign, like a frictionless ball bouncing between two walls.
Likes Dr_Nate
Thank you!
I've got an outline of a solution. Are you competent at vectors and derivatives?
I'm student-level at vectors and derivatives. I've done basic vector calculus and all that. I'm confident I can solve simple problems involving these things.
Here's the first two hints:
  • If a particle moves directly at another particle, mathematically how is this represented?
  • You'll also need to write out an equation for the motion of particle 1, which will be used later.
