Find the limit of the sequence n^3/(2n^3 + n)
  • Thread starter Thread starter walter9459
    Limit Sequence
The limit of the sequence defined by the expression n^3/(2n^3 + n) as n approaches infinity is conclusively 1/2. To justify this result using the definition of a limit, one must divide both the numerator and denominator by n^3, simplifying the expression to 1/(2 + 1/n^2). The next step involves finding a suitable N for every epsilon such that the inequality |1/(2 + 1/n^2) - 1/2| < epsilon holds true for n > N. A recommended choice for N is greater than 1/(2*sqrt(epsilon), ensuring the limit is valid.
  • Understanding of limits in calculus
  • Familiarity with epsilon-delta definitions of limits
  • Basic algebraic manipulation skills
  • Knowledge of sequences and their convergence
  • Study the epsilon-delta definition of limits in detail
  • Practice finding limits of sequences using algebraic techniques
  • Explore convergence criteria for sequences in calculus
  • Learn about the properties of limits involving rational functions
Students studying calculus, particularly those focusing on sequences and limits, as well as educators seeking to clarify the epsilon-delta definition of limits.
walter9459
Find the limit for the following sequence and then use the definition of limit to justify your result.
n^3/(2*n^3 + n)
I found the limit as n --> infinity is 1/2. I think the next step is to set up the equation as follows:
n^3/(2*n^3 + n) = 1/2
But then I'm not sure if I should add n+1 to each side.
Don't do any such thing. Look at the definition of a limit. Divide numerator and denominator of your expression by n^3. So you have 1/(2+1/n^2). Now you want to find an N for every epsilon such that n>N implies |1/(2+1/n^2)-1/2|<epsilon for any epsilon however small. Isn't that what the definition of limit said? Can you do that?
okay, I came up with 1/(2+1/n^2) which is where I came up the idea that the limit as n---->infinity is 1/2. But then if I set it to be < epsilon. How do you know what epsilon should be? I am really struggling with this concept. I appreciate your help and patience.
Think of epsilon as a really small positive number. You want to find an N so large that 1/2-1/(2+1/n^2)<epsilon for n>N. If you do the algebra that's 1/(4N^2+2)<epsilon. Since 1/(4N^2+2)<1/(4N^2) if 1/(4N^2)<epsilon then you have a good N. I would pick an N bigger than 1/(2*sqrt(epsilon)). Do you see why? If you can find an N for every epsilon then the limit is valid.
