Find the point when velocity is momentarily zero
The discussion focuses on determining the time when the velocity of a block, subject to a drag force described by $$F(v)=-F_0e^{Kv}$$, becomes momentarily zero. The derived expression for this time is $$t=\frac{m}{F_0K}(1-e^{-Kv_0})$$. Additionally, the position of the block at this moment can be calculated using the integrated equations of motion, leading to the expression for position when velocity is zero as $$x=-\frac{mv_0}{F_0K}e^{-Kv_0}-\frac{m}{F_0K^2}e^{-Kv_0}+\frac{m}{F_0K^2}$$. The discussion emphasizes the importance of correctly applying integration techniques and the implications of initial conditions in solving the problem.
  • Understanding of Newton's second law of motion (F=ma)
  • Familiarity with exponential functions and their properties
  • Knowledge of integration techniques, particularly with respect to initial conditions
  • Basic concepts of kinematics and motion under drag forces
  • Study the application of L'Hospital's rule in calculus for resolving indeterminate forms
  • Explore the derivation and implications of drag forces in physics
  • Learn advanced integration techniques, particularly integration by parts
  • Investigate the behavior of exponential decay in physical systems
Students in physics, particularly those studying mechanics and dynamics, as well as educators looking for examples of motion under drag forces and integration techniques in problem-solving.
vbrasic
[/B]
A block travels in the positive x-direction with some velocity ##v_0##. It is subject to a drag force $$F(v)=-F_0e^{Kv},$$ where ##F_0,\,K## are positive constants. Find the point in time when the velocity of the block momentarily goes to zero. Find how far the block has traveled at this time. Take intial time to be ##t=0## and initial position to be ##x=0##.
Just ##F=ma##, and some kinematics equations.
We have that $$F=m\frac{dv}{dt}=-F_0e^{Kv}.$$ Rearranging gives $$\frac{dv}{e^{Kv}}=-\frac{F_0}{m}dt\rightarrow e^{-Kv}dv=-\frac{F_0}{m}dt.$$ We integrate both sides subject to intial conditions as follows: $$\int_{v_0}^{v}e^{-Kv'}dv'=\int_{0}^{t}-\frac{F_0}{m}dt'.$$ This gives, $$-\frac{1}{K}(e^{-Kv}-e^{-Kv_0})=-\frac{F_0}{m}t\rightarrow e^{-Kv}-e^{-Kv_0}=\frac{F_0K}{m}t\rightarrow e^{-Kv}=\frac{F_0K}{m}t+e^{-Kv_0}.$$ Taking the natural logarithm of both sides gives, $$-Kv=\ln{(\frac{F_0K}{m}t+e^{-Kv_0})}\rightarrow v=v_0\ln{(\frac{F_0K}{m}t)}.$$ So evidently the velocity is zero when $$\ln{(\frac{F_0K}{m}t)}\rightarrow t=\frac{m}{F_0K},$$ My problem arises when I try to find the position of the object at this time. We have, $$v=\frac{dx}{dt}=v_0\ln{(\frac{F_0K}{m}t)}.$$ So, $$dx=v_0\ln{(\frac{F_0K}{m}t)}dt.$$ Integrating to initial conditions, we have, $$\int_{0}^{x}dx'=\int_{0}^{t}v_0\ln{(\frac{F_0K}{m}t')}dt'.$$ So, $$x=v_0t(\ln{(\frac{F_0K}{m}t)}-1)\bigg|_{0}^{t}.$$ However, ##\ln{0}## is undefined. So I'm not sure how to proceed. Rather, I'm quite sure I need to use L'Hospital's rule. Just not sure how to get the former term into the form $$\frac{f(x)}{g(x)}.$$
vbrasic said:
[/B]
Your step
$$-Kv=\ln{(\frac{F_0K}{m}t+e^{-Kv_0})}\rightarrow v=v_0\ln{(\frac{F_0K}{m}t)}$$
is false. You just have
$$v = -\frac{1}{K} \ln\left( \frac{F_0 K}{m}t + e^{-K v_0} \right) ,$$
and it does not really simplify any further.
Ray Vickson said:
Your step
$$-Kv=\ln{(\frac{F_0K}{m}t+e^{-Kv_0})}\rightarrow v=v_0\ln{(\frac{F_0K}{m}t)}$$​
$$v = -\frac{1}{K} \ln\left( \frac{F_0 K}{m}t + e^{-K v_0} \right),$$​
So basically $$\frac{F_0K}{m}t+e^{-Kv_0}=1\rightarrow t=\frac{m}{F_0K}(1-e^{-Kv_0}),$$ when velocity goes to 0?
As solutions go, how does this look.
We have, $$F=ma=m\frac{dv}{dt}=-F_0e^{Kv}.$$ This can be rearranged to, $$e^{-Kv}dv=-\frac{F_0}{m}dt.$$ Then, we can integrate both sides subject to specified initial conditions. We have, $$\int_{v_0}^{v}e^{-Kv'}dv'=\int_{0}^{t}-\frac{F_0}{m}dt'\rightarrow -\frac{1}{K}(e^{-Kv})\bigg|_{v_0}^{v}=-\frac{F_0}{m}t\rightarrow \frac{1}{K}(e^{-Kv}-e^{-Kv_0})=\frac{F_0}{m}t.$$ We can rearrange to solve for velocity by, $$e^{-Kv}=\frac{F_0K}{m}t+e^{-Kv_0}\rightarrow -Kv=\ln{(\frac{F_0K}{m}t+e^{-Kv_0})}\rightarrow v=-\frac{1}{K}\ln{(\frac{F_0K}{m}t+e^{-Kv_0})}.$$ Then, to find the instant at which $v=0$, we solve for the zeroes of this express. Because ##K## is a constant, it remains that, $$\ln{(\frac{F_0K}{m}t+e^{-Kv_0})}=0,$$ such that, $$\frac{F_0K}{m}t+e^{-Kv_0}=1.$$ Solving for $t$ we have, $$t=\frac{m}{F_0K}(1-e^{-Kv_0}),$$ when ##v=0##. It remains to find position as a function of time, such that we can find the position of the particle when velocity is ##0##. We note that, $$F=m\frac{dx}{dt}\frac{dv}{dx}=mv\frac{dv}{dx}.$$ Then we have that, $$mv\frac{dv}{dx}=-F_0e^{Kv}\rightarrow ve^{-Kv}dv=-\frac{F_0}{m}dx.$$ Again, integrating both sides we have, $$\int_{v_0}^{v}v'e^{-Kv'}dv'=\int_{0}^{x}-\frac{F_0}{m}dx'.$$ Integrating by parts we have, $$-\frac{1}{K}v'e^{-Kv'}\bigg|_{v_0}^{v}+\frac{1}{K}\int_{v_0}^{v}e^{-Kv'}dv'=-\frac{F_0}{m}x.$$ Then, $$-\frac{1}{K}(ve^{-Kv}-v_0e^{-Kv_0})-\frac{1}{K^2}(e^{-Kv'}\bigg|_{v_0}^{v})=-\frac{F_0}{m}x,$$ and, $$-\frac{1}{K}(ve^{-Kv}-v_0e^{-Kv_0})-\frac{1}{K^2}(e^{-Kv}-e^{-Kv_0})=-\frac{F_0}{m}x.$$ It remains to find ##x## when ##v=0##. We have (when ##v=0##), $$\frac{v_0}{K}e^{-Kv_0}+\frac{1}{K^2}e^{-Kv_0}-\frac{1}{K^2}=-\frac{F_0}{m}x.$$ Rearranging gives, $$x=-\frac{mv_0}{F_0K}e^{-Kv_0}-\frac{m}{F_0K^2}e^{-Kv_0}+\frac{m}{F_0K^2},$$ when ##v=0##.
That looks correct to me, although I would simply have integrated ##vdt## to get ##x##.
PS I would tidy up the final answer by grouping terms. And, check that you get ##x=0## if ##v_0=0##.
  • · Replies 27 ·
  • · Replies 18 ·
  • · Replies 19 ·
