Find the rate of change of the current in the inductor
The problem involves determining the rate of change of current in an inductor within a circuit, given a specific current from the battery. The context includes understanding the relationship between current, voltage, and inductance in electrical circuits.
  • Participants discuss the significance of the battery current and its relevance to the inductor's current change. Questions arise about the relationship between voltage across the inductor and the rate of change of current.
Some participants have provided insights into the circuit's behavior, including the relationship between the inductor and the resistors. There is an ongoing exploration of how to calculate the voltage across the inductor and its implications for the current change rate.
Participants express confusion regarding the problem setup and the role of given values, indicating a need for clarification on circuit relationships and definitions.
machinarium
For the circuit shown in Fig. 7, what is the rate of change of the current
in the inductor when the current in the battery is 0.50 A?
(1) 600 A/s (2) 400 A/s (3) 200 A/s (4) 800 A/s (5) 500 A/s
i(t)=Imax(1-e-tR/L)
induced emf = L (dI/dt)
I didn't fully understand the problem. I don't understand why the current in the battery was given? What would I use that value for?
Please explain to me what I need to know to find out the rate of change of the current. Thank you very much.
Think: How is the voltage across the inductor related to the rate of change of current?
ehild
Can you explain to me the whole problem? Please don't ask such a question, I was already very confused.
Thank you.
The current through the battery is the same as through the 20 ohm resistor. The voltage across the inductor is the same as across the 10 ohm resistor, as they are connected in parallel. Can you find this voltage?
ehild
The current through the inductor will be changing with time. As a result, the total current being drawn from the battery will also change with time. By asking what the rate of change of the current through the inductor will be when the current through the battery is a given amount, it is equivalent to asking for the rate of change of the inductor current at a specific moment in time.
Ah, I remembered it. Thank you for your commitment, ehild and gneill
The potential through the inductor is 12 – (20 ohm X 0.5 A) = 2 V
Then dI/dt=2V/10mH=200 A/s
Is that correct?
The answer is correct.
You might refer to the potential across the inductor, rather than through the inductor; Potentials are "across", currents are "through".
Potential is defined at a point. Potential difference or voltage is across a resistor or coil, or between two points.
ehild
ehild
"Across" implies two points are involved. "potential across" is sloppy shorthand for potential difference across. mea culpa.
  • · Replies 16 ·
  • · Replies 55 ·
  • · Replies 18 ·
  • · Replies 19 ·
