Find the Root-Mean-Square of the gas
  • Thread starter Thread starter VitaX
    Gas
The discussion focuses on calculating the root-mean-square velocity (Vrms) and molar mass of a gas at a given temperature and pressure. Using the ideal gas law (PV = nRT) and the relationship between density and molar mass, participants derive the molar mass (M) as 0.027 kg/mol and Vrms as approximately 497 m/s. The ideal gas constant R is utilized in both atm and SI units, with the final calculations confirming the accuracy of the results.
  • Understanding of the ideal gas law (PV = nRT)
  • Knowledge of root-mean-square velocity formula (Vrms = sqrt(3RT/M))
  • Familiarity with unit conversions (g to kg, atm to Pascals)
  • Basic principles of gas density and its relation to molar mass
  • Learn about the ideal gas law applications in real-world scenarios
  • Study unit conversions for pressure and density in gas calculations
  • Explore advanced topics in thermodynamics related to gas behavior
  • Investigate the implications of using different values for the gas constant R
Chemistry students, physicists, and anyone involved in gas law calculations or thermodynamic studies will benefit from this discussion.
VitaX
At 329 K and 1.37 x 10-2 atm, the density of a gas is 1.39 x 10-5 g/cm3. (a) Find vrms for the gas molecules. (b) Find the molar mass of the gas.
PV = nRT
Vrms = sqrt(3RT/M)
I could do this problem right now if there was a molar mass given in the question. How does the density help with finding the answer to the problem? I don't see any examples utilizing it so I'm not sure what to do.
Hint:
Try to find a relation between density and molar mass from the equation PV=nRT
n=m/M , where m is the mass of the gas and M the molar mass
All I can see is that density = mass/volume. So you are saying to replace n with m/m? And then set the equation equal to M? So it would be M = mRT/PV and substitite it in for M in the Vrms equation? So then it would be M = D(RT/P) and substitute that in for M in the Vrms equation? Or I guess I could find M right then and there and that gives me answer to part b then just plug M into the Vrms equation and that finds Vrms. Is that basically the solution to this problem?
Pressure in Pascals, density in kg/m^3 right?
Its better this way. Use R=0.0821 Lit atm K-1mol-1 because pressure is given in atm. Substitute the 'D' as it is and you will get 'M' in g units
Once you find out M in g units, convert it in kg units and plug it in your equation for Vrms. Use R in SI units here.
I was always told to conver to Pascals for pressure and use 8.31 J/mol*K for R. But I'm sure either works. I believe what I got is correct. I got M = .027 Kg/mol and Vrms = 497 m/s roughly.
The first value looks good.
Please show your work on the second.
M = D(RT/P) = .0127(8.31*268/1030.2) = .027 Kg/mol
Vrms = sqrt(3RT/M) = sqrt(3*8.31*268/.027) = 497.47 m/s
11K
9K
