Find the second smallest element
  • Topic:
  • Thread starter evinda
    Element
58 replies · 10K views · last reply
evinda
MHB
Hi! (Nerd)
Show that,given a set of numbers $S$,we can count the second smallest element of $S$ with $n+ \lceil \lg n \rceil-2$ comparisons at the worst case.
Hint: Find the smallest element,considering a tournament tree for its finding.
I don't really know how to use the hint.. (Sweating) Could you help me? (Blush)
Build a tournament tree by first pairing the $n$ elements together, and the smaller element of the pair advances to the next round of the tournament. This will yield a binary tree of height $\left\lceil{\log_2 n}\right\rceil$.
Also, the number of comparisons needed to create this tree would be defined by the recurrence $T(n) = T(n/2) + \frac n2$, and $T(1)=0$. because at each round, we do $\frac n2$ comparisons and move onto the next round. That recurrence has a solution of $T(n) = n - 1$.
After $n-1$ comparisons to build the tree, we know the root of the tree (the winner) is the smallest element. All we need now is to go to each depth of the tree and find out the element that the winner beats. There will be $\left\lceil{\log_2 n}\right\rceil$, we can find the minimum of this set with $\left\lceil{\log_2 n}\right\rceil - 1$ comparisons (linear scan).
Total number of comparisons is $n-1 + \left\lceil{\log_2 n}\right\rceil - 1$.
evinda said:
Hi! (Nerd)
Hey! (Happy)
Let's pick an example.
Suppose we have the following tournament tree:
What is $n$?
What is the number of comparisons to find the winner?
And what is the number of additional comparisons we need to find number 2? (Wondering)
  • Binary tournament tree diagram with 8 leaves: root 8, internal nodes 5 and 8, leaves 5, 3, 7, 8 with arrows pointing down from the bottom nodes.
I like Serena said:
Hey! (Happy)
What is $n$?
$n=4$,right? (Wasntme)
Number of comparisons=3
Is it maybe like that:
Number of additional comparisons=Number of comparisons-1=2 ? (Thinking)
Right!
Good!
Can you express that as a relationship with $n$?
Sorry, but no.
Perhaps we should look at an example with $n=8$... (Thinking)
I like Serena said:
Good!
It is equal to $n-1$..
I like Serena said:
Sorry, but no.
I created a turnament tree for $n=8$:
But..how can I find the number of additional comparisons we need to find number 2? (Thinking)
  • Complete binary tournament tree with eight leaves: 5, 7, 1, 2, 4, 6, 9, 7. Winners propagate upward; root is 9, with internal nodes 7, 9, 7, 2, 6, 9.
Yep!
Which contenders might be second best? (Wondering)
Starting at the left, could contender 5 be second best?
No,because $5<7<9$,right? (Thinking)
Correct.
From the position in the tree, you already know that $5$ cannot be second, but $7$ might be.
Which others are there? (Wondering)
I like Serena said:
Correct.
The possible numbers that could be second are these: $7,2,6,7$.
Then,these: $7,7$.
And,then,this: $7$.
Right? (Thinking)
Then,these: $7,7$.
And,then,this: $7$.
Right? (Thinking)
From the tournament tree, we have already had a match between $7$ and $2$, and $7$ came out on top.
So $2$ cannot be second. At best he is third.
We haven't had a match between $6$ and $7$ though. So both are still contenders for second place.
Btw, you have a duplicate $7$ in the bottom right. (Doh)
Was that intentional?
Or should it really be for instance $8$? (Wondering)
I replaced $7$ by $8$:
So,now do we have to find the greatest number,less than $9$,from the right subtree and compare it with $7$?
So,the number of comparisons is $4=\frac{n}{2}$ ,right? (Thinking)
  • Binary tree diagram with 16 leaf nodes and a root labeled 9; internal nodes read 7, 9, 7, 2, 6, 9 and leaves read 5, 7, 1, 2, 4, 6, 9, 8 from left to right.
The second best will come out on top everywhere - except when compared with number one.
There are three numbers that are on top, but that lose from number one: $\enclose{circle}7$, $\enclose{circle}6$, and $\enclose{circle}8$.
These are the candidates for second best.
The number of these candidates corresponds to the height of the tree minus 1.
What is the height of a binary tree with $n$ leafs? (Wondering)
Hint: it is not $\frac n 2$.
Now suppose we have $m$ candidates for number two.
Then we can create a new tournament tree, for which we already know that we need $m-1$ comparisons.
Isn't the height of a binary tree with $n$ leafs equal to $\lfloor \lg n\rfloor$ ? Or am I wrong? (Thinking)
But..in our case, $ \lg n-1=\lg 8-1=\lg {2^3}-1=3-1=2$,and there are $3$ candidates..or not? (Sweating)
So,is it like that? (Thinking)
  • Binary tree diagram with three levels: root 8 has left child 7 and right child 8; the left 7 has children 7 and 6; the right 8 has one child 8.
Let's see... if we have $n=1$ leafs, what is the height of the tree?
If we have $n=2$, what is the height of the tree?
If we have $n=4$, what is the height of the tree?
If we have $n=8$, what is the height of the tree?
If we have $n=16$, what is the height of the tree?
If we have $n=15$, what is the height of the tree?
If we have $n=9$, what is the height of the tree? (Wondering)
Yep. That's the tree for second best.
So it takes 2 comparisons. (Smile)
If we have $n=1$, height=1.
If we have $n=2$, height=1.
If we have $n=4$, height=2.
If we have $n=8$, height=3.
If we have $n=16$, height=4.
If we have $n=15$ ,height=4.
If we have $n=9$, height=3.
Right? (Thinking)
(Nod)
Yep! (Smile)
In this case we have 2 leaves and 1 root.
That means there are 2 levels.
Or in other words, the height of the tree is 2 instead of 1. (Worried)
  • Binary tree diagram with a root node labelled 2 at the top and two leaf nodes labelled 2 and 1 below, each joined to the root by an arrow pointing up.
I thought that,if there is just one node,the root node,the height is equal to $0$,if there are $2$ levels of nodes,the height is equal to $1$ and so on. Am I wrong? (Thinking)
I have just looked it up and I see conflicting information.
In binary tree on wiki, the height is the same as the number of levels.
But in tree (data structure) on wiki, the height is the number of levels minus one.
So I don't know! (Doh)
I'll just refer to levels from now on to avoid the confusion.
So with your interpretation, you are (almost) right!Still...
With $n=8$ leaves we have a full binary tree with 4 levels.
With $n=9$ we need one more level, so we have 5 levels! (Worried)
Can you find the formula for the number of levels based on the number of leaves? (Wondering)
So with your interpretation, you are (almost) right!Still...With $n=8$ leaves we have a full binary tree with 4 levels.
So, is it of this form, for $n=8$? (Thinking)
If so,why do we need one more level for $n=9$ ? (Thinking)
  • Binary tree diagram with seven nodes drawn as circles: a root at top, two children, and four leaves at the bottom level, with the left subtree having two leaves.
evinda said:
So, is it of this form, for $n=4$? (Thinking)
That tree has $n=5$ leaves... :confused:
So it has one level more than a tree with $n=4$ leaves.
Oh yes,right! (Blush)
So, is it like that? Or have I done something wrong? (Thinking)
number of leaves =1, number of levels=2
number of leaves =2, number of levels=2
number of leaves =4, number of levels=3
number of leaves =8, number of levels=4
number of leaves=16, number of levels=5
number of leaves=15, number of levels=5
number of leaves=9, number of levels=5
Almost!
If we have 1 leaf, there is only 1 node, and only 1 level.
How about a formula? (Wondering)
So, does the tree have to be complete? (Thinking)
number of leaves =$n$, number of levels= $\lceil \lg n \rceil+1$
Right? (Thinking)
That is the way to set up a tournament tree, so let's do it that way. (Mmm)
Right? (Thinking)
Right! (Nod)That brings us to how many candidates we have for second place. (Thinking)
And finally how many comparisons we need in total. (Thinking)
A ok... So, if at the beginning, $n$ is equal to an odd number,for example, $9$, is it then like that?
So, in order to find the first place, we need $n-1$ comparisons and then, in order to find the second place, we need $\lceil \lg n \rceil+1-1= \lceil \lg n \rceil$ comparisons.
Therefore, we need in total $n+ \lceil \lg n \rceil -1$ comparisons, right? (Thinking)
But..the exercise asks to show that we need $n+ \lceil \lg n \rceil−2$ comparisons... :eek:
  • Binary tree diagram with nine leaf nodes; the root has a left subtree of eight leaves and a right child leaf attached directly to the root.
It is not a complete binary tree, but yes, we can also do it like that.
Let's do this carefully to avoid any plus-or-minus-one mistakes. (Worried)
Take a look at our tree with $n=8$ leaves.
It has $\lceil \lg n \rceil + 1 = 4$ levels yes?
How many candidates for second place does that make?
Is it the same or is it different? (Wondering)
(Nod)
There are $\lceil \lg n \rceil=3$ candidates for the second place, right? (Thinking)
Right! (Smile)
How many comparisons do we need to find number two? (Thinking)
I like Serena said:
Right! (Smile)
We need $\lceil \lg n \rceil-1=2$ comparisons, to find number two, right? (Thinking)
