Find the Taylor series of a function
10 replies · 2K views · last reply
songoku
Find the Taylor series of ##f(x) = \frac{1}{(2 - x)^2}## centered at 0
##a. f(x) = \sum_{n=0}^\infty \frac{n+1}{2^{n+2}} x^n##
##b. f(x) = \sum_{n=0}^\infty (-1)^n \frac{n+1}{2^{n+2}} x^n##
##c. f(x) = \sum_{n=0}^\infty \frac{n}{2^{n}} x^n##
##d. f(x) = \sum_{n=0}^\infty \frac{n+1}{2^{n+1}} x^n##
##e. f(x) = \sum_{n=0}^\infty \frac{n+2}{2^{n}} x^n##
Taylor series
Maclaurin series
Standard power series
Because the Taylor series centered at 0, it is same as Maclaurin series. My attempts:
1st attempt
[itex] \begin{align}<br /> \frac{1}{1-x} = \sum_{n=0}^\infty x^n\\<br /> \\<br /> \frac{1}{x} = \frac{1}{1-(1-x)} = \sum_{n=0}^\infty (1-x)^n\\<br /> \\<br /> \frac{1}{x^2} = \sum_{n=0}^\infty (1-x^2)^n\\<br /> \\<br /> \frac{1}{(2-x)^2} = \sum_{n=0}^\infty (1-(2-x)^2)^n\\<br /> \\<br /> = \sum_{n=0}^\infty (-x^2 + 4x -3)^n\\<br /> \\<br /> = \sum_{n=0}^\infty (-1)^n (x-3)^n (x-1)^n<br /> \end{align}[/itex]
Then how to continue?2nd attempt: I do the derivative manually and put it into Maclaurin series formula and I end up with:
## f(x) = \sum_{n=0}^\infty \frac{(n+1)!}{2^{(n+2)}} x^n##
Is my answer on 2nd attempt wrong? Or the choices of the question are wrong?
Thanks
songoku said:
Problem Statement: Find the Taylor series of ##f(x) = \frac{1}{(2 - x)^2}## centered at 0
Relevant Equations: Taylor series
Maclaurin series
Thanks
You're quite close. You probably just made a mistake somewhere.
PS what about using the binomial series?
I found my mistake. The answer is (a)
How about my first method? Can it be continued to get the answer or it is just wrong from the beginning?
Thanks
Thanks
I can't see immediately where it goes wrong, but if you try ##x = 0## you have a divergent series. I suspect there are issues with convergence somewhere along the way.
Is it correct if I say like this: since I derive the series from ##\frac{1}{1-x}## then x ≠ 1. I used the previous series to find the series of ##\frac{1}{x}## so x ≠ 0. Finally, I used it again to get series for ##\frac{1}{(2-x)^2}## so x ≠ 2.
In total, x can not be 0, 1, and 2?
Thanks
Thanks
I'm not so sure. The series must converge for ##x = 0##. You've got problems for ##x > 1## as well.
Ok, I'll think about it again. Thank you for the help Perok
If you notice that ##\frac d{dx}\left(\frac{-1}{x - 2}\right) = \frac 1 {(x - 2)^2} = \frac 1 {(2 - x)^2}##, you can find the Maclaurin series for ##g(x) = \frac {-1}{x - 2}##, and then differentiate w.r.t. x, giving you the series for the function in your problem. I suspect that this is what the author of the problem had in mind.
I believe @PeroK's hint in post #2 is related to this idea.
Thanks Mark44
I rewrote the function as
##f(x) = \frac14 (1 - \frac{x}{2})^{-2}##
and used a binomial expansion.
