Find the volume of the solid obtained by rotating the region
The volume V of the solid obtained by rotating the region bounded by the curves y = 5x and y = 5√x about the line y = 5 is calculated using the formula A(x) = π(R² - r²). The correct radii are R = 5 - 5x and r = 5 - 5√x, leading to the integral V = π∫₀¹(25x² - (10/3)x^(3/2))dx. The final volume is V = (21/3)π. The error in the initial attempt was not properly accounting for the axis of rotation and the correct setup of the radii.
  • Understanding of solid of revolution concepts
  • Familiarity with integration techniques
  • Knowledge of the disk method for volume calculation
  • Ability to sketch and analyze curves
  • Study the disk method for calculating volumes of solids of revolution
  • Learn about the washer method for cases with inner and outer radii
  • Practice integration of polynomial functions
  • Explore applications of volume calculations in physics and engineering
Students in calculus, mathematics educators, and anyone involved in geometric modeling or engineering applications requiring volume calculations of solids of revolution.
Gundown64
Find the volume V of the solid obtained by rotating the region bounded by the given curves about the specified line.
y = 5x, y = 5\sqrt{x} about y = 5
A(x)=∏(R2-r2)
A(x)=∏(5x)2-(5\sqrt{x})2)
A(x)=∏(25 x2 - \frac{10}{3}x\frac{3}{2})
V=∏\int^{1}_{0}(25x2- \frac{10}{3}x\frac{3}{2})dx
V=∏(\frac{25}{3}x3-\frac{4}{3}x\frac{5}{2}) {0,1}
V=∏(\frac{25}{3}-\frac{4}{3})
V= \frac{21}{3}∏
Where did I go wrong? I can't figure out the about y=5. If I am correct, you would usually subtract 5 from the two radii, but since they intersect at y=5, the just flip on that intersection point and thus we don't need to find the lost area. Bad explanation, I know, maybe someone can explain it to me.
Thanks in advance!
A(x)=∏(R2-r2)
You've made an error right off the bat. I hope you sketched the region being rotated.
You aren't taking into account the fact that the axis of rotation is the line y = 5. The larger radius, R, is 5 - 5x. The smaller radius, r, is 5 - 5√x.
Also, your relevant equation is missing a factor - Δx. If you substitute the values above for R and r, you should get the right result.
V= \frac{21}{3}∏
Thanks in advance!
Ok, that's what my question at the end was about. I wasn't sure if I was supposed to subtract the radii from 5. I'll try it out and see how it goes. Thanks!
  • · Replies 27 ·
