Find the x Coordinate of the Center of Mass of 3 Chocolate Blocks
The x coordinate of the center of mass for three chocolate blocks with masses 0.310 kg, 0.410 kg, and 0.200 kg, located at coordinates (0.200 m, 0.310 m), (0.110 m, -0.380 m), and (-0.280 m, 0.610 m) respectively, is calculated using the formula (mass1*x1 + mass2*x2 + mass3*x3) / (m1 + m2 + m3). The correct calculation yields an x coordinate of approximately 0.0555 m. The user initially miscalculated the x coordinate but corrected it after recalculating without rounding errors, confirming the result with assistance from other forum members.
  • Understanding of center of mass calculations
  • Familiarity with basic algebra and arithmetic operations
  • Knowledge of mass and coordinate systems
  • Experience with calculator functions for precision
  • Review the concept of center of mass in physics
  • Practice calculating center of mass for different shapes and mass distributions
  • Learn about error analysis in calculations
  • Explore the use of software tools for physics simulations
Students studying physics, particularly those focusing on mechanics and center of mass calculations, as well as educators looking for practical examples in teaching these concepts.
Heat
Three odd-shaped blocks of chocolate have the following masses and center-of-mass coordinates:
(1) 0.310 kg, ( 0.200 m, 0.310 m);
(2) 0.410 kg, ( 0.110 m, -0.380 m);
(3) 0.200 kg, ( -0.280 m, 0.610 m).
Find the x coordinate of the center of mass of the system of three chocolate blocks.
This is how I commenced,
I took (mass1*x1+mass2*x2+mass3*x3)/(m1+m2+m3) and got .051
this should be right but I got it wrong. I then redid the calculation and this time I got .05
not that much difference, I only got one try left, and don't think this is right because they are so close together.
I did the y the same way and got it right. :S
Please and thank you.
Well, then you have put in the wrong numbers somewhere (I assume that even though you have written m3*x2, that should read m3*x3)
It is impossible for us to know how you clicked about on your calculator.
You should, at least, calculate the following:
\frac{0.310*0.200+0.410*0.110-0.2*0.28}{0.92}=\frac{0.062+0.0451-0.056}{0.92}=\frac{0.0457}{0.92}
which ought to be about what you've found already..
for some reason, either my calculator is wack, for the numerator I keep on getting
.062+.0451-.056 = .0511
for the denominator I get .92
.0511/.92 = .055543478
:cry:
edit: I tried it on windows, and I get .0511 too. :O
for your x i got .055543. try that and see if it works. I did it how you had it up there and that is what I got. I did this on my homework yesterday and got it right so it should be right. :)
yep, it's right thanks. I it just as it showed in the calculator this time without any rounding. :)
thank you princessfrost and arildno for your help.
  • · Replies 25 ·
