Find w (frequency) using energy equation
  • Thread starter Thread starter martin12005
    Energy Frequency
6 replies · 7K views · last reply
martin12005
A particle of mass M moves in one dimension along the positive x axis, under the influence of two forces. The first force is a constant force, with magnitude B and direction toward the origin. The second force is an inverse square law, with magnitude A/x2 and direction away from the origin. Find the potential energy function, and sketch the energy diagram for motion with kinetic energy K. Find the equilibrium position.
Calculate the frequency of small oscillations around the equilibrium. [Data: M = 0.68 kg; B = 36 N; A = 30 Nm2.]
Force=30*x**-2 - 36 = -du/dx
u= 30*x**-1 + 36*x
du/dx= -30*x**-2 + 36 set equal zero get equalibrium xzero value
d**2u/dx**2= 60x**-3
xzero at equalib= (30/36)**.5
k=d**2u/dx**2= 60x**-3 letting x=(30/36)**.5 so k=78.86
m=0.68 given above// so w= (k/m)**.5 w=(78.86/.68)**.5= 10.78 1/s
BUT W= 10.78 1/s is wrong, WHY? Thanks for any help
the formula for W(omega) = (k/m)^0.5 is derived for the spring force as proportional to x. the force you have(A/x^-2) is inversely proportional to x. I have a feeling you are getting an error there.
i tried to do it... but i got a really screwed up differential equation.
you have the correct equation but don't forget the w=2*pi*f
QUOTE=toastie;2239204]you have the correct equation but don't forget the w=2*pi*f[/QUOTE]
Hi,
I tried the 2*pi yielding 67.7 Rad/sec. That apparently was not correct according to the system that checks our answers. Thank you for the suggestion!
you have the angular velocity and you need to find the velocity. So if w=10.78 then f=?
Hi Toastie,
You are correct! I guess this was a time I overlooked the basics.
Thanks for the help,
Martin12005
