Find x when 1, √2, x, x² have range 4
  • Topic:
  • Thread starter alextrainer
    List Mystery
4 replies · 2K views · last reply
alextrainer
List contains 1, square root of 2, x and x squared and the list range is 4.
I guessed 2 but it is not correct.
Hi alextrainer. Would you please explain what a "list range" is?
I am going to assume that a "list range" is the difference between the largest and smallest elements in the list. So, if we assume then that we are going to have $x^2$ as the largest member of the list (since we will require $1<x$), where $1$ is the smallest, then we need:
$$x^2-1=4$$
Can you solve this where $1<x$? Is $\sqrt{2}<x^2$?
Another solution arises from assuming $x$ will be the smallest member of the list and $x^2$ will be the largest:
$$x^2-x=4$$
Can you find this solution?
You got the problem correctly stated?
x squared - x = 4
so not an integer
without just randomly trying fractions, what other strategy?
x squared = 4 - x? does not help
Let's first look at:
$$x^2-1=4$$
Add $1$ to both sides:
$$x^2=5$$
Hence, taking the root where $1<x$, we obtain:
$$x=\sqrt{5}$$
And so the list contains (ordered from smallest to largest):
$$\{1,\sqrt{2},\sqrt{5},5\}$$
We can see the "list range" is:
$$5-1=4$$
Next, let's look at:
$$x^2-x=4$$
Arrange in standard form:
$$x^2-x-4=0$$
Using the quadratic formula and taking the root such that $x<1$, we obtain:
$$x=\frac{1-\sqrt{17}}{2}\implies x^2=\frac{9-\sqrt{17}}{2}$$
$$\left\{\frac{1-\sqrt{17}}{2},1,\sqrt{2},\frac{9-\sqrt{17}}{2}\right\}$$
$$\frac{9-\sqrt{17}}{2}-\frac{1-\sqrt{17}}{2}=4$$
