How Do You Find a Basis for the Orthogonal Complement of Given Vectors in ℝ5?
To find a basis for the orthogonal complement of vectors u and v in ℝ5, one must ensure that any vector w in the space W satisfies the conditions wTu = 0 and wTv = 0. The discussion reveals that while the zero vector is trivially orthogonal, it does not form a basis since it is not linearly independent. An augmented matrix approach is suggested to derive a solution set, leading to the identification of three vectors that are orthogonal to both u and v. The final basis is confirmed to be a set of vectors derived from the constraints imposed by the orthogonality conditions. Understanding that a basis must consist of linearly independent vectors is crucial in this context.
ichabodgrant
Let u = [1, 2, 3, -1, 2]T, v = [2, 4, 7, 2, -1]T in 5.
Find a basis of a space W such that wu and wv for all wW.
I think the question is quite easy. Given this vector w in the space W is orthogonal to both u and v. I can only think of w being a zero vector. But would this be too trivial?
wTu = wTv = 0
wT(u - v) = 0
I believe there is something wrong. Things above are what I can compute...
Is there any other way to solve this question?
Oh, I've thought of another way.
Set a augmented matrix
[1 2 3 -1 2 | 0]
[2 4 7 2 -1 | 0]
[1 2 3 -1 2 | 0]
[0 2 4 3 -3 | 0]
Let x5 = t, x4 = s, x3 = z where t, s, z ∈ ℝ.
∴ x2 = 1.5t - 1.5s - 2z
x1 = -5t + 4s + z
Therefore, the solution set is {t[-5 1.5 2 0 0 1]T + s[4 -1.5 0 1 0]T + z[1 -2 1 0 0]T}.
The basis is {[-5 1.5 2 0 0 1]T, [4 -1.5 0 1 0]T, [1 -2 1 0 0]T}.Is this correct?
ichabodgrant said:
wTu = wTv = 0
You have started OK, but then you have hurried along too fast. Let w = [w1, w2, w3, w4, w5]. Now apply your conditions (written as scalar products: \left\langle w, u \right\rangle = 0 and \left\langle w, v \right\rangle = 0 ). You will not find a complete solution (after all, there are 5 variables and two equations), but you will have some constraints on the coordinates.
So my second try is correct?
Better to let w1, w2, w3, w4, w5 instead of x...?
No.
The first vector in your set has too many components (typo?). Each vector in your set has to be perpendicular to u and v, which you can easily check by doing dot products.
Yeah typo...sorry
the 2 is redundant
Seems like W would be the intersection of the ortho complements of u,v .
I would do it this way- write the general vector in your subspace as (a, b, c, d, e). Such a vector is perpendicular to (1, 2, 3, -1, 1) if and only if a+ 2b+ 3c- d+ e= 0. It is perpendicular to (2, 4, 7, 2, -1) if and only if 2a+ 4b+ 7c+ 2d- e= 0. Adding those two equations together, 3a+ 6b+ 10c- d= 0 so that d= 3a+ 6b+ 10c. Putting that into either or the first equations let's you solve for, say, e in terms of a, b, c, and d. Replace d and e in (a, b, c, d, e) by those and then write the result as a( ...)+ b(...)+ c(...).
for your first answer that w=0, you should understand that a set of vectors with the zero vector is never linearly independent. Think about it for a bit. You can easily prove it yourself. And if you don't have a linearly independent set then you don't have a basis. A basis is defined to be a linearly independent spanning list afterall.
Ahmad Kishki said:
for your first answer that w=0, you should understand that a set of vectors with the zero vector is never linearly independent. Think about it for a bit. You can easily prove it yourself. .
A 1-line proof: take any non-zero c , then c.0=0 is a non-trivial combination that gives you 0.
  • · Replies 52 ·
