Finding a formula for a sequence with recurring digits
  • Context: High School
  • Thread starter Thread starter spiritzavior
    Formula Sequence
10 replies · 4K views
spiritzavior
how do i determine the formula for the sequence below?
1,1,2,2,2,2,3,3,3,3,3,4,4,4,4,4,4,4,4,...,n,n,n,n,n,...,n,...
need some instructions. thanks in advance
Ok, there are subsequences of equal entries (increasing by one) in a row, and the numbers of equal entries in each of them form the following sequence:
2, 4, 5, 8, ...
I can't see any regularity. Sorry.
I can't see a pattern here: you have two 1s, four 2s, five 3s and eight 4s. Can you confirm that you've written it out correctly?
Seems like one too many 2's with n-1 repeated F(n+1) times for n = 2,3,4,5,... .
sorry, I've typed it incorrectly, it should be:
1,1,2,2,2,2,3,3,3,3,3,3,4,4,4,4,4,4,4,4,...
two 1s, four 2s, six 3s, eight 4s,...
If you don't mind the use of [] (integer part of) it's [1/2 +√(n-3/4)]
So, there are [itex]2 n[/itex] n's. The total number of elements no smaller than n is:
[tex] \sum_{k = 1}^{n}{2 k} = n(n + 1)[/tex]
Thus, all the elements with an index k that satisfies:
[tex] (n - 1) n < k \le n (n + 1)[/tex]
are equal to [itex]x_k = n[/itex] (why?). Can you find n, given k from the above inequalities?
[tex] n^2 + n - k \ge 0 \Rightarrow n \ge -\frac{1}{2} + \sqrt{k + \frac{1}{4}}[/tex]
[tex] n^2 - n - k < 0 \Rightarrow n < \frac{1}{2} + \sqrt{k + \frac{1}{4}}[/tex]
If you know the [STRIKE]floor[/STRIKE] floor function, which is the same as integer part for positive integers, you should be able to deduce:
[tex] x_k = \mathrm{Ceiling} \left[ \sqrt{k + \frac{1}{4}} - \frac{1}{2}\right][/tex]
[itex]a(n) = round(\sqrt{n})[/itex] seems to work, not that I could prove it.
This is where a(1) is the first entry in the sequence.
Good intuition abacus...
A000194 n appears 2n times; also nearest integer to square root of n
http://oeis.org/A000194
If one desires that digits are repeated 2n - 1 times, that's an easy one: floor [sqrt n]
The definition of ceiling and round functions is:
[tex] \mathrm{Ceiling}(x) \equiv n, \ n \le x < n + 1[/tex]
[tex] \mathrm{Round}(x) \equiv m, \ \vert x - m \vert < 1/2[/tex]
(the last definition is ambiguous if the argument is half-integer, but there can never happen for acabus's argument)
We want to know for what x, and y, [itex]\mathrm{Ceiling}(x) \stackrel{?}{=} \mathrm{Round}(y) = n[/itex]. From the above definitions, this happens when:
[tex] n \le x < n + 1, \ n - 1/2 < y < n + 1/2[/tex]
or, if we rewrite these inequalities for n, we get:
[tex] x - 1 < n \le x, \ y - 1/2 < n < y + 1/2[/tex]
Then, a necessary and sufficient (why?) condition is:
[tex] x - 1 < y + 1/2, \ y - 1/2 < x[/tex]
In our case, [itex]x = \sqrt{k + 1/4} - 1/2[/itex], and [itex]y= \sqrt{k}[/itex], so we have:
[tex] \sqrt{k + 1/4} - 1/2 - 1 < \sqrt{k} + 1/2 \Leftrightarrow \sqrt{k + 1/4} - \sqrt{k} < 2[/tex]
[tex] \sqrt{k} - 1/2 < \sqrt{k + 1/4} - 1/2 \Leftrightarrow \sqrt{k + 1/4} - \sqrt{k} > 0[/tex]
The second inequality is surely true, but the first is proven as follows:
[tex] \begin{array}{l}<br /> \sqrt{k + 1/4} - \sqrt{k} \stackrel{?}{<} 2 \\<br /> <br /> 0 < \sqrt{k + 1/4} \stackrel{?}{<} \sqrt{k} + 2 \\<br /> <br /> k + 1/4 \stackrel{?}{<} k + 4 \sqrt{k} + 4 \\<br /> <br /> 0 \stackrel{\surd}{<} \sqrt{k} + 15/16<br /> \end{array}[/tex]
This is surely true. Therefore, both the formulas give the same output for all positive integers.
Thanks all for your responses.
