Finding a frequency to create a given amplitude in a spring
11 replies · 16K views · last reply
ViXXoR
Damping is negligible for a 0.155 kg object hanging from a light 6.30 N/m spring. A sinusoidal force with an amplitutde of 1.70 N drives the system. At what frequency will the force make the object vibrate with an amplitude of 0.440 m?
So:
[tex]m=0.155kg[/tex]
[tex]k=6.30N/m[/tex]
[tex]F=1.70N[/tex]
[tex]A=0.440m[/tex]
So a given equation is:
[tex]A = \frac{\frac{F}{m}}{\sqrt{\beta^2 - \beta o^2 + (\frac{b\beta}{m})^2}}[/tex]
Also:
[tex]\beta o = \sqrt{\frac{k}{m}}[/tex] so [tex]\beta o = \sqrt{\frac{6.30}{0.155}} = 40.6452 rad/s[/tex]
And:
[tex]f = \frac{\beta}{2\pi}[/tex]
Damping is negligible so [tex](\frac{b\beta}{m})^2}} = 0[/tex]
Rearranging the first equation for [tex]\beta[/tex]:
[tex]\beta = \sqrt{\frac{(\frac{F}{m})^2}{A^2} + \beta o^2[/tex]
Plug in all the values:
[tex]\beta = \sqrt{\frac{(\frac{1.70}{0.155})^2}{0.440^2} + 40.6452^2}<br /> <br /> = 47.6799 rad/s[/tex]
Now using the formula for frequency:
[tex]f = \frac{\beta}{2\pi}<br /> <br /> = \frac{47.6799}{2\pi}<br /> <br /> = 7.5885 Hz[/tex]
It seems my answer is wrong, and I cannot find out where I am going wrong. Any advice would be greatly appreciated.
Thanks
You made a mistake here:
You forgot to take the square root.
Wow...
Thank you for pointing that out.
Hmmmmm...turns out that when I take the square root, the answer is more wrong. I'm really stumped.
ViXXoR said:
Wow...
do you know the answer?
I get 4.095Hz. is that what you're getting?
Yes, that's exactly what I am getting. It is still marked as wrong though.
And they want the answer in Hz?
Yes, they want the answer in Hz.
It seems they want 2 frequencies, a "Lower" one and a "Higher" one.
Ah... I think I see the problem now... the square root shouldn't be there:
[tex]A = \frac{\frac{F}{m}}{\beta^2 - \beta o^2}[/tex]
If I use that equation, how will I get 2 frequencies out of it? Also, the square root is in the equation in my textbook...
Are you sure?
The formula I'm seeing online is:
[tex]A = \frac{\frac{F}{m}}{\sqrt{(\beta^2 - \beta o^2)^2 + (\frac{b\beta}{m})^2}}[/tex]
which isn't what you had... you didn't have the extra square inside... when there's no damping... the square root and square cancel each other.
Maybe the 2 values are the plus/minus square root...
So:
[tex]\beta = +/-\sqrt{\frac{(\frac{F}{m})}{A} + \beta o^2[/tex]
[tex]\beta = +/- 8.0976 rad/s[/tex]
Frequency = +/- 1.289Hz ?
Awesome, you're right! One thing, can you have a negative frequency? Can I have my higher frequency at 1.289hz, and my lower one at -1.289Hz?
If High frequency is:
f_high = ([tex]\beta[/tex])/(2*pi)
In order to find the low frequency:
f_low = ([tex]\beta[/tex])/(4*pi)
I got mine right that way.
