Finding a knot in an infinitely long rope
  • Context: High School
  • Thread starter Thread starter mishima
    Rope
68 replies · 9K views
Regardless of the probability distribution of the position of the knot, it is somewhere at a fixed, finite position. Once that is established, any issues of infinity are gone from the problem.
Blargus said:
Aren't you also saying that 1/n is never going to be zero and n is never going to be ∞?
Yes. For any finite value of n, 1/n will never be equal to zero. The idea with limits is that we can make 1/n as close to zero as anyone else requires.
Blargus said:
Hm, if I'm understanding aren't you confusing the limit as n approaches infinity for the value of n which it definitely can never be? Doesn't the limit as n “approaches infinity” here result in a valid probability for n?
No, I'm not confusing anything here. And, no, the limit as n "approaches infinity" doesn't have any connection with probabiity.
Further, the way this type of limit is defined mathematically doesn't mention "approaches infinity." What it does say is that no matter how close to zero someone else requires, we can specify a finite number M so that 1/M is closer to zero than what was required.
Blargus said:
If n= infinity it doesn't but if n=a jillion or a jillion gazillion etc. as in a limit "guess" calculation explained above doesn't it result in a valid probability for that guess?
Again, limits have no connection with probabilities. Also, "infinity," "jillion," and "jillion gazillion" aren't numbers in the real number system.
PeroK said:
You should use the reply feature!
I second this. The part in quotes below is actually a quote from @FactChecker, but you wouldn't know that as it was written.
Blargus said:
"If I talk about all the real numbers between 0 and 1 inclusive, I can indicate that by [0,1] or by ##\{x\in \mathbb{R}: 0\le x\le1\}##. That is an infinite set. In fact, ##\mathbb{R}## is an infinite set.. That is an infinite set."
I wonder if you did define a set maybe you just set boundaries or something. If you can't designate or enumerate separate things in the set do you have a set of things?
Setting boundaries for an interval on the real number line defines that set. It's not possible to enumerate all of the elements in an infinite set. On the other hand, if you tell me a number, I can tell you whether that number belongs to the interval [0, 1].
Blargus said:
Maybe like infinite ropes not existing the infinite set of R doesn't either?
Of course, infinite ropes or the real number line are abstractions don't "exist" in the real world sense, but so what? The concept of an ellipse is an abstraction, yet planets revolving about the sun follow elliptical paths. A parabola is an abstraction, yet we can use this abstraction to predict with some accuracy the flight of an arrow.
Blargus said:
Not sure I can understand even defining a starting point on a supposedly infinite length.
How about the nonnegative real number axis -- the interval ##[0, \infty)##. Call 0 the starting point.
If that's not real enough for you, imagine that you start at Lat. 0.00° Long. 0.00° (out in the middle of the Gulf of Guinea, off the west coast of Africa). Head east in a boat and when you reach land, hop in your airplane and continue east. Keep going east until you eventually wind up at your starting point, but instead of stopping, keep heading east without ever making a final stop. The path you're on has infinite length, but has a defined starting point.
Blargus said:
Guess I'm looking at it philosophically. Not sure I can understand even defining a starting point on a supposedly infinite length.
I can see your objection if you are talking about defining a general definition of the "starting point for a rope" that is infinite in both directions. If it is only infinite in only one direction, then you can say that the end in the other direction is a "starting point for the rope".
But I didn't interpret the OP that way. I interpreted it as saying that you pick any point on the rope and call that the starting point of your search for the knot. I don't see any problems with calling that a "starting point".
If the searcher has infinite time to search or can do it infinitely fast then sure any point can be found. But that's non-physical and this is a physics forum. I say the poster intended a finite search, which will find the knot on an infinite rope with probability zero.
This is not correct.
Any point on the rope can be reached in finite time.
If I can search the rope at 1 metre per second and the knot is r metres from the beginning then I will reach the knot in r seconds.
He can start anywhere on the rope and move along it. He can always find the knot in finite time because he is a finite distance from the knot.
I guess I'm saying if you understand n as the number of items in a set and you're wondering about a set with an infinite number of items and the probability of choosing one, can't you set up lim n→∞n and look at it to see what n does and set up lim n→∞1/n to see what the probability of choosing n does? And if you do that you see evidence that you can't have a set with zero items or an infinite number of items? Which seems to make sense? So you can use that as a useful guideline that maybe infinite sets don't exist? I dunno. I guess it's a matter of belief. Sorry to be petulant I guess I'll have to look at what mathemeticians say about supposed "infinite sets" though maybe it gets into "set theory" if that's like "literary theory" maybe I'll pass and just have a possible inkling that mathematics is doing some evil weird stuff like other branches of science are. Sorry my opinion.
If I start at that nonexistant point (infinitely small?), to define that point as real don't I define it as the physical dimensions of my body at that point? Or the size of a the boat or a quarter or a pinhead etc.? As I travel I trace a path along the globe based on my physical dimensions or the unit I want to use which can be as small as I choose. But I can't reasonably say there's no unit?
Let's indicate that point on a map it's going to be the size of the pen tip, let's go to it in reality it's going to be the size of us standing together at a reasonable polite distance unless we're fighting off sharks back to back with the last of our flare gun ammo while the UFO decides to pick us up. I dunno it might be a matter of belief or conception or something.
  • Skeptical
The probability of choosing one item of an infinite set is zero.
##\lim_{n \to \infty} n = \infty## and ##\lim_{n \to \infty} \frac 1 n = 0##.
Keep in mind the the symbol ##\infty## doesn't represent a number. All the first limit is really saying is that the larger n gets, the larger n gets. (Duh...). What the second limit says is that the larger n gets, the smaller and closer to 0 that 1/n gets. In mathematics these limits are defined much more precisely than the words I used.
A set with no elements in it is called an empty set. Saying that you can't have a set with no elements in it is a little like saying that it doesn't make sense to have zero of some item. A counterexample to that is when you have a checking account with $78.05 in it and you write a check for $78.05, then your account balance will be $0.00. The empty set serves a similar purpose as zero does in the real numbers.
As far as sets with an infinite number of items, they don't exist in reality, but mathematics is not restricted to dealing only with real, physical things. Most things in mathematics are abstractions, including numbers themselves.
Yes, very much so.
Set theory is nothing like so-called "literary theory."
That point exists -- it's on the map.
??? That point is defined by latitude and longitude coordinates. I don't see that the coordinates have anything to do with the dimensions of your body. Of course, to start out at the point I mentioned, you'd have to be satisfied by being within a few feet of it.
The units of the point are in terms of degrees, minutes, and seconds of latitude and longitude. As you travel east you can keep track of your current position either by the coordinates of other points you reach or by the distance you've traveled, which would usually be in terms of miles or kilometers. I don't know why you would want to keep track of your position other than by using degrees, minutes, and seconds or in terms of miles/kilometers covered.
You seem to be hung up on standing exactly on a particular point. It's OK if you are merely close to it. My point in this thought exercise was to get you to think about a possible infinitely long journey that had a defined endpoint.
From post 18:
Blargus said:
OK but is it not true that you can't make the set infinitely large, that you have to limit it to define it as a set? That you can't have an infinite set because you can't put brackets around it.
No, that isn't true. Are you under the mistaken impression that for any set, all of its members have to be in the form of a list?
We can define a set like this, with all elements explicitly listed: A = {2, 4, 6, 8, 10}.
We can also define the same set using what is called set-builder notation. E.g., ##A = \{2n = \mathbb Z : 1 \le n \le 5\}##. In more explanatory form, this is the set of even integers from to to 10 inclusive. Here ##\mathbb Z## is a symbol that represents the integers.
We can define infinite sets using intervals: ##[0, \infty)## or using set-builder notation: ##\{x \in \mathbb R : 0 \le x < \infty\}##. Here ##\mathbb R## is a symbol that represents the real numbers.
Well I guess I'm trying to make a philosophical point whether valid or not it seems like it is to me.
Keep in mind the the symbol∞ doesn't represent a number. All the first limit is really saying is that the larger n gets, the larger n gets. (Duh...). What the second limit says is that the larger n gets, the smaller and closer to 0 that 1/n gets. In mathematics these limits are defined much more precisely than the words I used.
The point has already been made but isn't it just nonsense to say "the probability of choosing one item from an infinite set is zero?" I think I understand and agree with the rest.
If you draw a line of longitude and latitude according to the coordinates that intersect at that point, the lines must have some thickness to create a point thus the point must have some dimensions to exist. Maybe you can conceive of a line with no thickness or a point with no dimensions but it can't exist--be on the map--unless it has dimensions. edit: or can you even conceive of one really?
Ok but from what little I've checked it seems a set has no real definition in mathematics or a very broad one so maybe that's the argument we're having. I'm defining it as a group of things. If a set is a group of things and there are no things then there is no set.
  • Skeptical
That is a question that is discussed here and elsewhere occasionally. It is not a simple question. I personally have no problem with saying that a number between 0 and 1 has been selected using a uniform distribution, even though there are uncountably infinite numbers there, each with a zero probability.
I know that many people disagree with me, many who may be much smarter than me. But I don't have the brains or patience to worry about that.
The mathematical definition of a line is that it has no thickness. Although a human may not be able to draw the line, he can imagine it.
I think that you are conflating the mathematical definition of a line (and a point) with the ability of a human to draw one. The limitation of human ability is irrelevant.
If you want to give a line or a point some positive physical dimension, then you will have a lot of work to defend that. The rational numbers between 0 and 1 are countably infinite and dense. If rational points have some positive size, they will overlap.
I wonder if he can.
FactChecker said:
The rational numbers between 0 and 1 are countably infinite and dense... If rational points have some positive size, they will overlap.
If I'm understanding...isn't "countably infinite" a contradiction? How can you say an infinite quantity of things is dense or not?
Blargus said:
I wonder if he can.
Sure, IMO, a line with no width is easy to imagine.
Good question. The phrase in mathematics does not mean finite and countable. The rational numbers can be matched up one-to-one with the counting numbers, 1,2,3,... to infinity. That is called "countably infinite". On the other hand, there are too many irrational numbers to be matched up like that with the counting numbers. That is called "uncountably infinite".
Consider any open line segment, ##(x1,x2), 0 \le x1 \lt x2 \le 1##, in line from 0 to 1. No matter how small it is, there is a rational number, ##r##, in that line segment. ##x1 \lt r \lt x2##. That is called "dense" in [0,1].
I can't see mine because it has no width. Then I think well it must be there but since it has no width it can't be there either. Maybe if arbitrary or infinitesimal or unknown width ok there it is?
If I'm understanding I would say no you can't. But I'm not a math person anyway agree to disagree I guess.
What's the process to match them up? Ok let's start 1 goes to 1/a billion, 2 goes to...wait wait we missed one go back. Ok start 1 goes to 1/a billion billion 2 goes to....wait wait stop again, we missed one start again!
FactChecker said:
Regarding counting the rational numbers.
This explains how to count the rational numbers: Integers & Rationals are both infinite but is it the SAME infinity?
Well thanks seems like nonsense sorry. "The snake" is an interesting way of ordering rational numbers I guess not that I totally get it seems like you can't order them at all as a total group. But 6:00 he says "I'm going to get to every one of these positive rational numbers eventually." But you're not.
And 7:18 "there are so many more rational numbers than integers." Seems to me that just because you can seemingly order them on a number line in between integers doesn't mean there's more, because both go on forever.
Is there a ratio between them that for every integer there's so many natural numbers? No because for every 1 integer there's infinite natural numbers.
Just my opinion just seems like an error of reasoning maybe.
  • Sad
Yes, you are.
Any rational number, say 99/1000, will eventually be gotten to. The counting will wind around until it finally reaches up to the 1000th row and will start to include that row, starting with 1/1000. from then on, the counting will keep coming back up to that row (and beyond) and count 2/1000, 3/1000, etc. until it gets to 99/1000. There is no rational number that will not be counted.
mishima said:
TL;DR Summary: Choosing 1 from an infinite set
They have asked if there was a knot somewhere in an infinitely long rope, would the knot ever be reached if you iterated through the length hand over hand?
Yes. Hand size probably not important but no limit on rate is stipulated. Speed up the search for the knot, while honoring relativity, by pulling faster and faster on the (inelastic) rope. You could speculate decreasing search time by replacing hand-over-hand with a hand cranked pulley or motor. The finite rope can be measured as < Aleph-Null units of length, if you want to introduce George Cantor's transfinite labeling scheme.
FactChecker said:
Suppose that the knot is in a fixed place and you started at some place on the rope. You can reach the knot in a finite time. That is true even if you started going in the wrong direction. You could 10 steps in one direction, turn around and go 100 steps in the other, turn around and go 1000 steps in the original direction, turn around and go 10000 steps, etc. By alternating your direction that way, you would eventually reach the knot no matter how far away it was and even if you started in the wrong direction.
The concept of changing search direction also works while giving the nod to searches on tape, common in teaching computer science. As @FactChecker states, bi-directional searches readily allow starting your search at any random section of rope. The next search iteration in a previous direction would also be a likely time to increase the search speed.
Arguments introducing rope tensile strength and similar conditions miss the point of the thought exercise: introducing your students to set theory. This 1D exercise provides a good introduction to teaching 2D searches on a flat plane where "Drunkard's Walk" offers surprising optimal results searching randomly for, say, lost keys within a finite area.
You've taken completely the wrong attitude by favouring your own homespun ideas. That's no basis for discussion. Mathematics is what it is. It's not going to change because you don't like it or can't understand it.
If you want to learn mathematics we may be able to help. If you want to replace the established knowledge of mathematics with your own self-styled ignorance, then you are wasting everyone's time.
Whatever point you're trying to make isn't based on logic. As you say, you're not a math person, so IMO, you're in over your head here.
@PeroK gave a good explanation of why this is not nonsense in post 17. Did you read it?
You've totally missed the point of my analogy. It was not whether lines have thickness or points are dimensionless -- it was a thought experiment to provide an example of an infinite length that had a starting point.
"From what little I've checked" is key here. I agree that sets are loosely defined, for the reason that the most basic terms can't be defined by using more basic terms. Empty sets are allowed to provide for completeness. An empty set can be combined (the operation is called a union) with any other set so that the result in a new set that is identically the same as the one you started with. This is the set analog of 0 being the additive identity in arithmetic. I.e., for any number x, 0 + x is identically equal to x.
Again, PeroK gave a good explanation of why you if the numbers are assumed to be uniformly distributed, then the probability of picking a single number can't be larger than zero.
No, not at all, and this goes back to what you said about not being a math person.
You can say it if you know how the term "dense" is defined. Here's a link to a wikipedia page on this subject - https://en.wikipedia.org/wiki/Dense_set. The set of positive integers, {1, 2, 3, ..., n, ...}, is an infinite set, but this set is not dense in the real numbers. On the other hand, rational numbers are dense in the real numbers.
Once you get beyond the concept of finite sets, you learn that there are different "sizes" of infinite sets. Here are several infinite sets: the positive integers, the set of even positive integers, the rational numbers in the interval [0, 1], the real numbers. Although it seems counterintuitive, the first three sets are the same "size" in some sense, while the fourth set, the reals, constitute a much "larger" set.
Then your position is at odds with everyone in the world who has studied mathematics beyond the first year level in college.
Let's looks at a simpler example, with one set being the positive integers and the other the set of even positive integers. If I can demonstrate a one-to-one pairing between the two sets, then the sets have the same cardinality, the actual term that is used to compare sizes of infinite sets.
In the following, the first number is one of the positive integers and the second is one of the even positive integers.
1 gets paired with 2
2 gets paired with 4
3 gets paired with 6
n gets paired with 2n
If you tell me an element of the positive integers, I'll tell you what even integer it gets paired with. OTOH, if you tell me one of the even integers, I'll tell you the integer that it got paired with.
I have no idea what you're saying here.
Yes, you are making many errors of reasoning.
Let's see if this professor also gets deleted here as an "illegitimate source:"
"The Hilbert hotel, in my view and in the view of a mainstream of mathematics is not a true paradox in the sense of one that is reveals a deep contradiction in our conceptions. It is merely an appearance of such a problem. It requires us to reconfigure our default understanding of infinity. Much of what follows implements that reconfiguration. However for a minority view in mathematics, matters are otherwise. This minority view is not to be dismissed lightly, since it is held by some distinguished mathematicians. The dissenting view falls under the rather loose banner of "finitism." There are many versions of it. What unites them is a distaste for the actual infinities (as opposed to potential infinities), that are so readily embraced in the Hilbert hotel and other related analyses. Even Hilbert himself seems to have had some sympathies for a version of finitism. To say more goes well beyond what can be responsively covered here. If the view has a rallying cry, it might be Leopold Kronecker's 1886:
"Dear God made the whole numbers; everything else is the work of man.""
John D. Norton
Department of History and Philosophy of Science
University of Pittsburgh
https://sites.pitt.edu/~jdnorton/teaching/paradox/chapters/infinity_paradox/infinity_paradox.html
  • Sad
John D. Norton
John D. Norton is indeed a distinguished professor in the Dept. of History and Philosophy of Science, but he's no mathematician. It would be helpful if you could provide some citations to recent publications from "distinguished mathematicians" that espouse this "minority view".
I guess I could try though isn't that a job for the "math people?" Or people who can make any sense at all of math publications? I have a hard enough time with pubmed.
  • Sad
Blargus said:
I guess I could try though isn't that a job for the "math people?" Or people who can make any sense at all of math publications? I have a had enough time with pubmed.
Generally it is the responsibility of the person proposing a position to provide references supporting that position when asked to do so. If, by your own admission, you cannot make sense of math publications then I recommend not supporting a minority or fringe position on a topic. You can, of course, always ask for help finding and understanding such references, but it's a little odd to try to argue for a minority position that you yourself don't understand well enough.
You guys. It was told to me that my understanding on infinity or not believing you can make an infinite set was ridiculous, irrational, illogical and not held by anyone who has studied math beyond the first year. But hey I appreciate you trying I guess and the conversation helped me understand what my "problem" is.
Rather than continue to argue as I am not able to do with math I attempted to show by "legitimate sources" that this is actually a controversial topic in the history of mathematics at least at the turn of the last century and into the 20th.
So if you guys wanna not take that point because I can't find a 2023 journal article of Gobbledegook Theory Volume 80 then me and Leopold Kroeneker apparently will bid you adieu.
ATM I'm glad I can't live in "Cantor's Paradise" and I wonder if anyone should.
  • Sad
That's fine if you want to discuss the history of this topic, but those views are a century or more out of date now, so why bring them up? There have been many, many mathematicians in the last hundred years just as smart, productive, and knowledgeable as Cantor, Hilbert, and other mathematicians from the late 1800's and early 1900's, and the vast majority of them accept Cantor. So you can either believe that all of these people are absolutely and utterly wrong, or you can accept that maybe the situation is a bit more complicated than you understand and accept that they probably know a few things you don't.
Correction to the above: "this was actually a controversial topic" up until about 100 years ago. Only a few years before that many people also believed that travel faster than 60 mph would be fatal to humans.
I read the link to the Claes Johnson blog post that you linked to before it was deleted. It's interesting to me that this 2009 post of Johnson's had all of 2 votes. It's not surprising to me that computational mathematicians have a distaste for infinity, inasmuch as computers are limited to dealing exclusively with a finite set of numbers. I did find it surprising that Johnson included a quote from the author Jorge Luis Borges.
One of your "legitimate" sources was Kronecker, whose main quibble seems to have been that Cantor did not show the fractional numbers in complete form in his list. Every rational number can be represented in decimal form in which
a) some pattern terminates at some point, with all subsequent digits being 0 (e.g., 1/8 = 0.12500000...) or
b) some finite-length pattern repeats endlessly (e.g., 1/9 = 0.11111...). I doubt that even Kronecker would have a problem with the "dots" here.
However, it is well-known that irrational numbers such as ##\sqrt 2, \pi##, and others have decimal representations that never repeat and never terminate, so Kronecker's complaint that the numbers that Cantor listed weren't complete seems baseless to me. There is a reason that Cantor is so well-known more than a century after his death, while the only thing Kronecker is remembered for (at least by myself) is the Kronecker delta function.
Minor point: the last century was the 20th. We're now in the 21st Century.
"Don't let the door hit you in the butt on your way out."
Oh so now it's the "vast majority" not everyone who studies math and all mathematicians?
Mark44 said:
However, it is well-known that irrational numbers such as...pi , and others have decimal representations that never repeat and never terminate, so Kronecker's complaint that the numbers that Cantor listed weren't complete seems baseless to me.
Doesn't seem like you're seeing the issue clearly. My understanding is that you seem to think like the math prof in the video about the diagonal proof that "you will eventually get to every number." IMO this is a flagrantly wrong view of the infinite and if it is accepted by Cantor as it seems he does in statements it is wrong and he is misleading everyone "the vast majority."
Decimal representations that never terminate or repeat have a "complete" form as decimals? Are you saying pi in decimal form can be totally expressed by any method? Not potentially expressed to any desired length, totally expressed to the last decimal? Just NO for the last time by definition it cannot. It seems horrifying that this is apparently being argued against. It's a philosophical point that is there in calculus limits which protects it and if math has divorced itself from this point it is going the wrong way.
Oh 20th didn't go so well and 21st isn't either. Opinion of a fool!
Ouch but that makes it easier. Gonna have to discipline myself now to not come here anymore goodbye.
Lest quibbling be the last word on teaching infinity, George Cantor remains a rather tragic historical figure, attacked on many sides during his lifetime not only for his mathematics.
Depending on the biographer, Cantor attended Lutheran church but based on his name (and intellect IMO) was ethnically Ashkenazi. Grist for the mill based on his time and place.
Some mathematicians and math students including myself and several of my professors hold him in high regard for his contributions to human knowledge, often in the face of adversity and intense resistance to transfinite concepts.
Coincidentally, my early Summer reading includes new novels by my previous university math professor turned SF writer, Rudy Rucker. "White Light" features Georg Cantor as a supporting and explanatory character having afternoon tea with Albert Einstein and David Hilbert, naturally on the veranda of Hilbert Hotel. Einstein relates humorous anecdotes while Cantor pours.
