Finding a matrix whose nullspace consists of vectors orthogonal to two given vectors
29 replies · 4K views
negation
Let S be the subspace of all vectors in R4 that are orthogonal to each of the vectors
(0, 4, 4, 2), (3, 4, -2, -4)
What is an example of a matrix for which S is the nullspace?
I'm not sure how I should be intepreting the question:
[ 0 ,4 ,4 ,2 ;3, 4, -2, -4] = [ x , y ,z , t] = [ 0 , 0 ]
0x + 4y + 4z + 2t = 0
3x + 4y -2 z -4t = 0
from here I set up an augmented matrix and solve for the set of vectors x ,y ,z ,t? By definition if x, y, z, t results in each linear equation = 0, then, x ,y ,z ,t are vectors with properties of orthogonality?
There is multiplication instead of equality in the first line? If yes, it looks all right, do it.
ehild
ehild
[ 0 ,4 ,4 ,2 ;3, 4, -2, -4] .[ x , y ,z , t] = [ 0 , 0 ]
Yes, it should be a multiplicative operation-dot product.
But I aren't exactly sure what should I be doing with the 2 linear equation. Do I perform reduce row echelon?
Yes. But it is of that form already... You will have two free parameters.
ehild
ehild
I'm still unclear. Could you explain?
There is the system of equations:
What is the general solution?
ehild
ehild
It is done by setting up an augmented matrix:
0 4 4 2 | 0
3 4 -2 -4 | 0
Perform REF(Not RREF), then solve for the variables.
Edit: x1 = 2x3 + 2x4, x2 = -x3-0.5x4, x3, x4
ehild said:
Well, solve for the variables...
ehild
Post #7
X3=a, x4=b a,b free parameters. So the S subspace consists of vectors ((2a+2b); (-a-0.5b); a; b).
And a matrix for which S is the nullspace?
ehild
ehild
Relooking at the question, I'm not sure if we interpreted it correctly.
I think the question is asking for the {SX=0|x1=0,4,4,2, x2=(3,4,-2,-4),S[itex]\in R4[/itex]}
Edit: I think we were on the right track.
But this brings up a question. What if we're asked to solve S, given X where SX = 0?
Let's untangle your notation. S is a subspace of R4 such that if v ##\in## S, then v ##\cdot## <0, 4, 4, 2> = 0 and v ##\cdot## <3, 4, -2, -4> = 0.
The problem asks that you find a matrix (call it A) for which S is the nullspace of A. IOW, if v ##\in## S, then Av = 0.
ehild
Isn't the vector [2z+2t; -z-0.5t;z;t] the answer?
S is the nullspace of a linear transformation T, that is, Tv =0 for all vectors v[itex]\in[/itex]S. Show a matrix of that transformation. (You have shown one in Post #3) .
ehild
See post #12. The "answer" should be a matrix, not a vector.
In addition, what you have above would be better written as two vectors - a basis for S.
ehild
Am I suppose to perform another one? I thought we have had all the solutions already. 2 are free variables and the corollary is that there are infinite solutions.
The subspace S contains infinite number of vectors. You have found these vectors already.
The next question is
ehild
ehild
any matrix with coefficient [itex]\in R[/itex]?
basis for S : z (2,-1,1,0) + t (2,-0.5,0,1)
Your wording is peculiar. z (2,-1,1,0) + t (2,-0.5,0,1) is a general vector in S. The set of vectors {(2, -1, 1, 0), (2, -0.5, 0, 1)} is a basis.
The answer to this question is any matrix, A, such that A applied to each of those two vectors is 0.
Similar to what I said in post #12.
Mark44 said:
The problem asks that you find a matrix (call it A) for which S is the nullspace of A. IOW, if v ∈ S, then Av = 0.
I think I got it. Set any value for the free variables vand work from there.
I'm not sure you get it. As has been said multiple times, you need to find a matrix.
NO!
You have written in post #3:
When you perform matrix multiplication, you do the dot product of the vector v=(x,y,z,t) with the first line of the matrix as row vector and get zero, as the are normal to each other, and the same when multiply the second row of the matrix with the vector v. So one matrix A that fulfils equation Av=0 is ?
ehild
ehild said:
no!
When you perform matrix multiplication, you do the dot product of the vector v=(x,y,z,t) with the first line of the matrix as row vector and get zero, as the are normal to each other, and the same when multiply the second row of the matrix with the vector v. So one matrix a that fulfils equation av=0 is ?
Ehild
v1 = 0x + 4y + 4z +2t = 0
v2 = 3x + 4y -2z -4t = 0
for v1 and v2 = 0; (x,y,z,t) = (0,0,0,0)
zero vector!
Yes, it was. But negation had then asked the same question again.
negation,
This is becoming very frustrating for us. We have said in posts 10, 12, 14, 15, 17, 20, 21, 23, 24, and 26 that this problem is asking you to find a matrix. We can't say it more plainly than that.
HallsofIvy said:
What are you talking about? Have you found the matrix yet?
I have. It's (0,0,0,0),(0,0,0,0) which was correct.
Edit: Too many question to keep track of.
0,4,4,2
3,4,-2,-4
Mark44 said:
negation,
I apologized. I misread the question. But I found the answer to be (0,0,0,0),(0,0,0,0)
Edit: Opps, answer to wrong question. Too many question to keep track.
Ans:
0,4,4,2
3,4,-2,-4
