Finding a vector perpendicular to a plane defined by two vectors
18 replies · 3K views · last reply
Blockade
Problem: The vectors A and B together define a plane surface. Determine a vector of magnitude 3 that is perpendicular to that surface.
What I am thinking is Vector A is on the x-axis and B is on the y-axis. Therefore, the vector that I must determine, runs along the z-axis which is 90 degrees to that plain.
So, can I say that the answer is: The vector that must be determined is 90 degrees z-axis of x-axis with a magnitude of 3?
Sorry if what I am doing or saying is not even remotely close to the valid answer.
Can you please tell me how to approach this problem, maybe even go through it?
Here is a picture of what I think the Determined Vector of magnitude 3 is:
Picture URL: http://tinypic.com/r/25u16jd/8
Have you studied the cross product of vectors?
Two vectors are perpendicular if their dot product is zero.
No I haven't, I am still learning the basics. I will spend the rest of tonight looking over it.
So |A|*|B|*cos(theta) = 0
cos(theta) = 0 / (|A|*|B|)
theta = arccos(0)
theta = 90 degress
I can say that the VECTOR that is perpendicular to the plane is 90 degrees counterclockwise and have its magnitude = 3?
I think you should rather look at cross product
LOL, yeah I am, thank you.
So I am not sure, but this is what I got.
First I find the cross product of A and B, since it will give me a vector that is perpendicular to both A and B.
A x B = C
And now that I have C in vector components, but from here I am lost. Do I multiply it by 3 since it wants a "vector with a magnitude of 3"?
so 3C = 3*(# i + #j + #k) is my answer?
Can you tell me if this is wrong and explain to me the correct way?
A x B = C
And now that I have C in vector components, but from here I am lost. Do I multiply it by 3 since it wants a "vector with a magnitude of 3"?so 3C = 3*[#i + #j + #k] is my answer?
You should compute the magnitude of ##\mathbf{C} = \mathbf{A}\times \mathbf{B}##. You can either multiply ##\mathbf{C}## by an appropriate number to obtain a vector with magnitude 3 or derive a unit vector ##\hat{\mathbf{C}}## as an intermediate step and then multply that.
A x B = C
This is just about right. However, as Fzero just said, if the magnitude of C is not 1, then 3*C will not have magnitude 3, it will have magnitude 3|C|.
So for the second method that you mentioned you mean like this?
A: 4i + 3j - 2k
B: 2i - 3j - 2k
AxB = C = i -12j - 18k##\hat{\mathbf{C}}## = C / |C|
3*##\hat{\mathbf{C}}## = 3 * [-12i - 18k / sqrt(468)]
A: 4i + 3j - 2k
B: 2i - 3j - 2k
Yes, that's the general idea. But with ##\mathbf{A}## and ##\mathbf{B}## as given I find
$$\mathbf{A}\times\mathbf{B} = \begin{vmatrix} \mathbf{i} & \mathbf{j} & \mathbf{k} \\ 4 & 3 & -2 \\ 2 & -3 & -2 \end{vmatrix} $$
gives a slightly different result from yours. So recheck your calculation before working out ##\hat{\mathbf{C}}##.
A: 4i + 3j - 2k
B: 2i - 3j - 2k
Where did your i component go?
Sorry for line "AxB = C = i -12j - 18k", I meant to say AxB = C = 0i -12j - 18k.
I forgot to go back and fix it after realizing my Num Lock was off.
I am not going to lie, I find physics and things associated with the course to be very hard and that I am struggling. Therefore, thank you everyone for you guys' help.
I don't think you are handling the negatives properly.
I also get a different result.
