B Finding all possible sums given 2 lists, matched one to one
  • B
  • Thread starter Thread starter mishima
    Sums
To find all possible sums from two lists of numbers, A and B, where each element can only be used once, one must consider the permutations of the lists. The total number of permutations is calculated as n!, but this number is reduced due to repeated elements in the lists. The challenge lies in accounting for these duplicates to avoid counting the same sum multiple times. The user seeks guidance on efficiently calculating these sums, potentially using a spreadsheet for analysis. Ultimately, the goal is to explore all unique combinations of sums derived from the two lists.
mishima
Hi, its been a while since I have thought about this type of math, and I can't really remember how to do this or what its even called. I have two lists of numbers:
A: 8, 8, 9, 10, 7, 8
B: 6, 5, 4, 3, 3, 3
I want to find all the different ways I can add elements from A with elements of B. For instance, just adding them vertically as they are here I could get one combination as:
C: 14, 13, 13, 13, 10, 11
When an element from a list is used, its gone. For example, if I added 10 from A and 6 from B, I can't use 6 again (or vice versa). Can anyone nudge me in the right direction?
Mathematics news on Phys.org
The number of ways you can pick an entry in the A list to be added to an entry in the B list is the number of permutations, which is n! This number will be reduced by the fact that many of the sums are the same, which feels like a hard problem to handle.
Ok, so 720 possibilities. I could've sworn there was a way to account for repeats but like I said it has been a while since I have touched on this style of thinking. Ultimately I am just trying to make a spreadsheet to crunch it all out.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
