Finding amplitude of oscillating spring; x(t) and v(t) given
The discussion centers on calculating the amplitude of an oscillating spring given the initial position and velocity. The position at t = 0 is -27.33 cm and the velocity is +0.744 m/s. The equations used are x(t) = Acos(ωt + φ) and v(t) = -Aωsin(ωt + φ). The solution involves determining the angular frequency ω from the period of 4.22 seconds, which is calculated as ω = 1.488 rad/s, and using trigonometric identities to solve for amplitude A.
  • Understanding of harmonic motion equations: x(t) and v(t)
  • Knowledge of angular frequency calculation from period
  • Familiarity with trigonometric identities, particularly sin² + cos²
  • Basic algebra skills for solving equations with multiple variables
  • Learn how to derive angular frequency from the period of oscillation
  • Study the application of trigonometric identities in solving physics problems
  • Explore advanced topics in harmonic motion, including damping and resonance
  • Practice solving problems involving multiple unknowns in oscillatory systems
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators looking for problem-solving strategies in harmonic motion.
tensor0910
At t = 0 seconds, the position of the oscillator is found to be -27.33 cm and the velocity of the oscillator is +0.744 m/s. What is the amplitude of the oscillation?[/B]
position/time equation for oscillation: x(t) = Acos(wt + phi )
for velocity: v(t) = -Vmax sin(wt + phi )[/B]
at t = 0, the position is -.2733 m and the velocity is .744 m/s.
This leaves us with two equations with 2 unknowns. ( I think ) this is how they should look:
-.2733 = Acos(phi)
.744 = -.744sin (phi )
I unsuccessfully attempted to solve for either unknown and ended up with:
tan(phi ) = -A/-.2733
This is where I got stuck. Not even sure if my algebra is correct. Any/all tips are appreciated. Thank you in advance!
Edit: Original problem coupled with question. Sorry, forum noob here :-)
A mass of 1.4 kg is attached to a single spring and set into oscillation. The period of the spring oscillation is measured to be 4.22 seconds
[/B]
Hi tensor:
I see two things that appear to be not quite right in your work.
1. You omitted the equation v(t) = dx/dt.
2. How did you arrive at the value of the coefficient of sin in the quoted equation?
Hope this helps.
Regards,
Buzz
Likes tensor0910
Please do not bold face your posts. It violates forum rules.
tensor0910 said:
1. Homework Statement
2. Homework Equations
3. The Attempt at a Solution
-.2733 = Acos(phi)
If ##x = \cos(\omega t + \phi)## then ##v = \frac{dx}{dt} = -A\omega \sin(\omega t + \phi)##, so you have three unknowns ##A,~\omega,\text{ and }\phi##. Putting ##t=0## in those two gives two equations. And if you know the period is ##4.22## seconds, that should give you ##\omega##. It might be helpful to use the ##\sin^2 + \cos^2## identity in your work.
Likes tensor0910
thank you for the reply Buzz!
After relooking at the problem with Buzz's tip I came up with these equations:
-.2733 = Acos( Φ ) x(t)
.744 = -ωAsin( Φ ) v(t)
I solved for ω using 2π/T ( calculator in rad ) and came up with 1.488
solved for A: A = -.2733/cosΦ
plugged A into v(t) and came up with :
.744 = (.40667)(tanΦ)
isolated tan(Φ) and solved for Φ and came up with...1.070.
But the program says its wrong!
Does anyone have any ideas?
Edit: solved for Amplitude using -.2733/cos (1.070.)
Figured it out. Calculator needs to be back in Deg. to finish problem. Φ = 61.338. Plug into x(t)
Thank you Buzz and LCKurtz for the help!
Likes Buzz Bloom
The amplitude is asked, you do not need the angle.
-0.2733 = Acos( Φ ) = x(t)
0.744 = -ωAsin( Φ ) = v(t)
ω=1.489
You can write the second equation in form Asin( Φ ) = 0.744/ω. Square both this equation and the first one, add up the squares, and use @LCKurtz hint about sin2 + cos2.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
  • · Replies 17 ·
