Finding an affine transformation matrix
5 replies · 17K views · last reply
Staff Emeritus
Hey guys,
I have a problem in a computer vision application that requires me to find an affine transformation matrix, A.
What I've got are four corners of a quadrilateral, in 2D coordinates on the image plane. These are the projections of the 3D corners of the real quadrilateral onto the image plane.
What I need to find is the 3D affine transformation matrix, A, which transforms the corners of a unit square into the given corners. If I can easily determine if such a transform does not exist, that information would also be useful.
Methods using homogeneous coordinates are fine, of course.
Anyone have any ideas?
- Warren
if the corners of the image are A,B,C,D, let's translate back to the origin, by subtracting A from all of them.
Then A-A is at the origin, and we have three more points,oops. wait a minute, is this quadrilateral a parallelogram?
if not it seems hard to map a square onto it by an affine map. i.e. an affine map is just a translate of a linear map, and it seems a linear map must send a square to a parallelogram, no?
anyway, back to work: if we take two of the three translated corners say B-A, and C-A, we can make a matrix with those as columns.
then that matrix will send the unit square to the parallelogram spanned by 0 = A-A, B-A, and C-A. then translating back by A, will send the unit square to the parallelogram spanned by A,B,C.
but it might not send the 4th corner of the square to D, unless D-A = B-A + C-A, as vectors.
does this seem right?
here is a counterexample:
img530.imageshack.us/img530/2964/notaffinert8.png
Affine transformations map lines to lines; yours isn't affine.
Looks right to me; I got the same result (only works if the image is a parallelogram) in a different manner. Given two line segments lying on the same line, affine transformations preserve the ratio of their lengths. In particular, the diagonals of a square bisect each other -- and so that must also be true of its image, meaning it has to be a parallelogram.
In general, given the following information about a quadrilateral ABCD whose diagonals intersect at E:
. A
. B
. C
. AE / EC
. BE / ED
the point D is uniquely determined.
thats why its a counterexample...
