Finding an Upper Bound for e^(-x^2) for Easy Integration
  • Thread starter Thread starter Ted123
    Bound Upper bound
The discussion revolves around finding an upper bound for the function e^(-x^2) that can be integrated easily, particularly in the context of proving its Lebesgue integrability over the real numbers.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore potential upper bounds for e^(-x^2) and discuss the implications of integrating over different intervals, particularly [0, ∞) and [-n, n]. Questions arise regarding the convergence of integrals and the application of the comparison test.
The discussion is active, with participants questioning assumptions about the intervals and the nature of convergence. Some guidance has been offered regarding the use of simpler upper bounds and the properties of the function e^(-x^2), but no consensus has been reached on a specific upper bound.
Participants note that the integral of 1 diverges on [0, ∞), and there is an emphasis on the need for an upper bound whose integral converges. The context of using the Monotone Convergence Theorem is also highlighted.
Ted123
Can anyone suggest an upper bound for e^{-x^2} that can be integrated easily?
On what interval? Just guessing maybe ##[0,\infty)##? This is really easy. What have you thought of so far?
I've just realized it's less than 1 for all x.
You haven't answered the question about what interval, or told us what problem you are trying to solve.
It doesn't matter now; I know how to do it!
Not if you were trying a comparison test on ##[0,\infty)##.
It's actually on a finite interval [-n,n], but yes the integral of 1 would diverge on [0,\infty)
Are you asserting that "1 times infinity" is a finite number?
All I need to show is that \int_{-n}^n e^{-x^2} dx converges as n\to\infty. This is the last part of a bigger question where I'm trying to use the Monotone Convergence Theorem to show that e^{-x^2} is Lebesgue integrable over \mathbb{R}.
Since 0 \leqslant e^{-x^2} \leqslant 1 and \int_{-n}^n 1 \; dx =0 \to 0 as n\to\infty it follows from the comparison test that \int_{-n}^n e^{-x^2} dx converges as n\to\infty.
(I'm not asked to find \int_{\mathbb{R}} e^{-x^2}, just to prove it is Lebesgue integrable using the MCT.)
No, it isn't.
D H said:
No, it isn't.
Oh yeah, it equals 2n which diverges as n\to\infty.
But doesn't that contradict the comparison test?
I'm trying to show that \int_{-n}^n e^{-x^2}dx converges, but the comparison test implies it diverges.
Yep, it diverges, assuming you mean as \displaystyle\lim_{n\to\infty}. Why do you think it converges?
Well, OK. Let's start from scratch.
I'm trying to prove f(x) = e^{-x^2} \in L^1(\mathbb{R}) ; that is, that f is Lebesgue integrable over \mathbb{R}.
Let f(x) = e^{-x^2} \chi_{(-\infty , \infty)}(x) and f_n = f \chi_{[-n,n]}.
Since f\geqslant 0, (f_n) is an increasing sequence of functions which converges everywhere to f.
We want to show that f is integrable so it suffices to show \int f_n converges as n\to\infty. It then follows from the Monotone Convergence Theorem that f\in L^1 (\mathbb{R}) (and \int f = \lim_{n\to\infty} \int f_n).
We use the given hint ("don't try to find \int f ; integrate a simpler upper bound instead").
We see that f_n is bounded by... The integral of this upper bound converges, so by comparison test \int f_n converges.
Of course not. Given functions f(x) and g(x) such that 0\le f(x) \le g(x) for all x and such that \lim_{s\to\infty}\int_{-s}^s g(x) dx diverges says nothing about the convergence or divergence of \lim_{s\to\infty}\int_{-s}^s f(x) dx.
There are plenty of positive definite functions f(x) that are bounded from above by g(x)=1 whose integral over the real number line does converge. f(x)=\exp(-x^2) is one such function.
Oh yes, it's the other way around for divergence isn't it: if \int f(x) dx diverges then so does \int g(x) dx.
OK, so I need an upper bound whose integral converges then. Any suggestions?
No. That would be solving your homework for you.
Huge hint: if 0\le a \le 1 then \sqrt a \ge a, and if a\ge1 then \sqrt a \le a.
What about something with xe^{-x^2}
But if x<0 then e^{-x^2} > xe^{-x^2}
Do you care? exp(-x^2) is symmetric, so if the integral from 0 to infinity exists, then so does the integral from -infinity to infinity.
Bingo! If only I'd drawn a graph first...
Not only that, but if 0\leq x < 1 then it still holds that e^{-x^2} > xe^{-x^2}
But it is clear that since e^{-x^2} is symmetric about the y-axis as f(x)=f(-x), and the function is finite over x\in [0,1] then all you need to do is show that xe^{-x^2} is convergent for x\in [1,\infty).
  • · Replies 16 ·
