Finding $\angle ACB$ in $\triangle ABC$
  • Topic:
  • Thread starter Albert1
4 replies · 2K views · last reply
Albert1
$\triangle ABC ,\angle ABC =45^o,\,\,point \,\, D \,\, on \,\, \overline{BC}, \,\,and :$
$2\overline {BD}=\overline {CD},\,\,\angle DAB=15^o$
please find :$\angle ACB=?$
My solution:
This is most likely not what you're looking for but I couldn't resist to solve any given geometry problem with the help of my close friend, aka trigonometry, hehehe...:p:o
First let $BD=DE=EC=k$ and join DG and GF such that $\angle ABC=45^{\circ}=\angle DGB$, $\angle GDF=30^{\circ}=\angle DFG$ and $\angle DAB=15^{\circ}=\angle AGF$ so triangles $DBG$, $DGF$ and $AGF$ are isosceles with the congruent sides labeled as $k$.
Applying the Sine Rule to the triangle $DFG$ we have
$\dfrac{DF}{\sin 120^{\circ}}=\dfrac{k}{\sin 30^{\circ}}\,\,\,\implies DF=\sqrt{3}k$
Applying the Cosine Rule to the triangle $ACD$ we get
$AC^2=(2k)^2+((1+\sqrt{3})k)^2-2(2k)(1+\sqrt{3})k)\cos 60^{\circ}\,\,\,\implies AC=\sqrt{6}k$
Applying the Sine Rule again to the triangle $ACD$ we see that
$\dfrac{AC}{\sin 60^{\circ}}=\dfrac{AD}{\sin ACB}$
$\sin ACB=\dfrac{1+\sqrt{3}}{2\sqrt{2}}=\dfrac{1}{2}\cdot\dfrac{1}{\sqrt{2}}+\dfrac{\sqrt{3}}{2}\cdot\dfrac{1}{\sqrt{2}}=\sin 30^{\circ}\cos 45^{\circ}+\cos 30^{\circ}\sin 45^{\circ}=\sin(30^{\circ}+45^{\circ})=\sin 75^{\circ}$
$\therefore \angle ACB=75^{\circ}$.
  • Geometry diagram of triangle ABC with base BDEC and apex A, with points G on AB and F on AD; angles 45°, 15°, 30°, 60°, 90°, 120° marked, and segments BD, DE, EC labelled k.
anemone said:
My solution:
your answer is correct !,will you try to use geometry ?
(let geometry also be your close friend)
I in fact tried to tackle it geometrically and I thought it must have everything to do to prove that
the quadrilateral $AGDC$ is cyclic
but all of my attempts had been proven to be exercises in futility.(Doh)
My solution:
  • Geometry diagram of triangle ABC with point D on side AC and point E inside, with CE perpendicular to AD. Labels show angles 60°, 30°, 45°, 90°, 15°, 30°, lengths 1, 2, and √3, and the construction note: construct CE perpendicular to AD, let BD=1, then CD=2, DE=BD=1, CE=AE=BE=√3, so angle ACB = angle BCE + angle ACE = 30° + 45° = 75°.
