Finding angle for this resultant vector
The problem involves determining the angle between two displacement vectors given their magnitudes and the resultant displacement magnitudes. The subject area pertains to vector addition and trigonometry, specifically the law of cosines and sines.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to use geometric methods, specifically drawing triangles and applying the law of cosines and sines, to find the angle. Some participants question whether the approach taken is correct and suggest verifying the drawing method.
Participants are engaged in exploring the problem, with one suggesting a need to retry the calculations. There is an acknowledgment of a potential error in the original poster's approach, and guidance is offered to clarify the method of drawing the vectors.
There are variations in the displacement magnitudes and resultant values mentioned, indicating different scenarios being considered. The original poster expresses uncertainty about their method, and there is a reference to a website indicating an incorrect solution.
RandellK02
Hello I am working on this problem and just can't figure it out...
Consider two displacements, one of magnitude 3.0 m and another of magnitude 3.8 m. What angle between the directions of this two displacements give a resultant displacement of magnitude (a) 5.7 m, (b) 2.5 m, and (c) 3.6 m.
I have tried to draw the triangle and then use law of cosines and sines to find the appropriate angle but it seems to not be going the way I want it. Is this the correct solution or is there another way to go?
Any help is greatly appreciated.
Welcome to PF!
Hello RandellK02! Welcome to PF! :wink:
It should work.
(You are drawing the two given sides head-to-tail, aren't you?)
Show us one of your attempts. :smile:
Okay I will retry my math.
Thanks
Website states this is Incorrect.
Consider two displacements, one of magnitude 2.9 m and another of magnitude 4.4 m. What angle between the directions of this two displacements give a resultant displacement of magnitude (a) 5.6 m, (b) 2.9 m, and (c) 4.6 m.
98.1
40.7
75.0
  • · Replies 20 ·
12K
14K
